Results 1 to 11 of 11
Thread: Trane VAV
    Jun 2006
    New Jersey
    Trane VAV
    I'm looking for the stroke time on a Trane VAV. VSED2430. Any help would be appreciated.
    My comfortsite log in is not wokring.
    Feb 2012
    Upstate SC
    This may not be current but the last job I did with Trane VAVs they used Belimo operators. Typical stroke time was 35 secs. If it is a Belimo, they have all their tech. docs. on their website.
    Jun 2006
    New Jersey
    Quote Originally Posted by jburchstead View Post
    These are the older VAV's with the spline drive plug valves. Vintage "D".....1989.
    Feb 2012
    Upstate SC
    Quote Originally Posted by ascj View Post
    I remember seeing those, but in that vintage i was dealing with spring rates and not stroke times...sorry. I don't think Trane was real big in to controls back then. They used a lot of Honeywell or JCI if my memory serves me correctly.
    Nov 2005
    6 minutes
    I STARTED WITH NOTHING, AND I STILL HAVE MOST OF IT!
    Jun 2006
    New Jersey
    Quote Originally Posted by allstar08 View Post
    6 minutes
    Thanks, that's what I thought it was.
    Sent from my C771 using Tapatalk
    Jun 2006
    midwest
    6 min stroke time is correct
    Winter Haven, FL
    It does have a 4-6 minute stroke time. Keep in mind when you hook it back into the contol system its going to calibrate the vav, which can take up to 30 minutes.
    I know you don't need me to chime in on this, but it's 6 minutes.
    Also, make sure you have the right RPM on the motor, I know there are at least two different versions; 300 RPM and 600 RPM. There may be more. I'm sure you can imagine what kinds of problems having the incorrect motor would cause.
    The key to happiness is lower expectations.
    Don't pick the fly crap out of the pepper.
    Feb 2011
    Chesterfield, Virginia, USA
    6 minutes
    +1 (6 minutes).
    Jun 2006
    midwest
    i always replace the stroke switches along with the motor 300 or 600 rpm. the motors go bad when the gears shred on the shaft.
