Results 1 to 13 of 14
    Mar 2012
    Twinning of variable speed motor
    1)May I know why twinning of two variable speed motors in furnace is not done?
    2)I also like to know if it is because of lack of tecknology?or customer dont want such twinning on variable speed motor.
    3) Is there any requirement in market which demand twinning of variable speed furnace.
    4)Is there any OEM goodman,trane ,rhim who wants to do twinning on variable speed motor on furnace?
    Massachusetts
    ECM motors, whether variable speed or constant torque, operate based on static pressure feed back. They need to 'see' static pressure to determine how fast to rotate. Twinning reduces the static to zero, thus one the ECM motors will 'huff' and not turn up to speed. For after market ECM motors that also determine rotation automatically, they may also fail to establish the proper rotational direction. So ECM motors are not twinned, at least with the technology available today.
    It is notable that the various sizes of residential equipment, 40,000 to 140,000 Btu's for gas furnaces and 1.5 to 5.0-tons for AC and HPs is a product of what was considered a large home, average home and small home back in the 1950's. The manufacturers have maintained those sizes quite successfully for many, many years and obviously fail to see why they should increase them for the limited market that needs twinned products. Generally it's very large homes or commercial establishments that have twinned furnaces or air handlers. I reckon they'll have to survive with non-ECM motors until something changes.
    Carrier is working on twinning with variable speed furnaces that will be avail. in the near future. They will be using ecm motors with the older PWM rather than communicating technology. Not sure of how great the demand is for it but obviously if Carrier is going to have them there must be a market out there.
    Monitoring 2 variable speed blower equipped air handlers fighting it out over a common return is almost as entertaining as watching an oversized electronic bypass damper on a zoned system and a variable speed blower fight an ultimately futile battle for equilibrium.
    I don't think it is a problem with the fixed speed ECMs, like the X13. Since they aren't adjusting to duct conditions, they won't fight each other. At least Rheem & Nordyne, 2 that I looked at, say it is OK and have twinning on their boards.
    Correct, it isnt a problem with fixed speed ecm motors it is the variable speed motors that have not been able to be used. Like I mentioned previously Carrier will soon have true variable speed twinning capabilities using the older design PWM motors that do not communicate.
    AS/Trane ForeFront/Hyperion air handlers should be ok for twinning with the motors set for constant torque mode.
    I haven't looked to see if they are specifically approved for it though.
    Jun 2001
    In residential a home that's so large it needs TWO 140k furnaces probably should be zoned anyways.
    Nov 2001
    East Texas
    Attachment 257121
    Here is a wiring diagram i used last year on two x-13's. Worked great
    Feb 2012
    Opelousas La.
    I think the Hyperion vs air handler will revert back to constant cfm in the heating mode even if it is set on torque mode.
    Mar 2012
    It seems from above discussion that twinning for variable speed motor have considerable market but because of technical difficulties not coming in market.Is my assumption right?
    Jun 2001
    Quote Originally Posted by Rajan1 View Post
    IMHO the concept of twinning came from old leaky houses combined with contractors fear of under-sizing. If a house needs more than 140k of heat then fix the house instead of figuring out a way to add more heat. 140k of heat should be good for at least 5,000sqft, and at some point ductwork gets too long to distribute air effectively to all rooms. I can't think of any residence large enough that would need to be twinned, but I live in the south. Even commercial could benefit from having separate units in different areas of the business. Besides, most commercial jobs are roof top units anyways...
    Aug 2013
    Timber,
    Do you still have that diagram. I am looking to twin 2 TM9X Yorks. They have the x-13. The contractor was supposed to install the TG9S but ordered and installed the wrong furnace for the application. Can you help?
