Page 4 of 4 FirstFirst 1234
Results 40 to 45 of 45
Thread: A/C Leak Freeze
  1. #40
    Apr 2012
    I can't find any information on any stop leak for hvac that discusses any compatability issues. I am here because a home warranty company said they had good luck with it.
    Trane says it voids their warranties, Auto techs say it messes up their recovery equipment.
    Ever talk to someone who lost money in Vegas? They only remember the time when they were winning and you have to pry out the story how they lost it all back in spades. It's going to take more than "good luck" stories to convince me to use the stuff. I'm not using it until I see documentation.
  2. #41
    Jul 2005
    Tulsa
    A/C Leak Freeze?
    found this stuff being advertised on http://www.achrnews.com/articles/119...rigerant-leaks
    always thought sealers were crap and death for any system. working on an old R-22 system that has a leak with a hard to access copper run under a craw space.
    system holds 150 psi nitrogen for hours. but R-22 will leak out after several months.
  3. #42
    Nov 2005
    Kansas
    It's better to fix a leak the old fashion way but the sealers work quite well. I have systems out there running for years after adding sealant. I doubt that the sealants kill compressors even after some rare compressor failures shortly after adding sealant. The compressor failures have more to do with acid build up over time, system abuse (dirty coils) or running a long time low on refrigerant than on adding the sealant.
    I add the sealant only in old systems to extend the life of it.
    Have not seen any negative effect on my tools either and I keep them for years.
    It's a lot of hoopla about nothing.
  4. #43
    Jul 2005
    Tulsa
    Quote Originally Posted by tostaos View Post
    which brand sealer have you used successfully?
  5. #44
    Nov 2005
    Kansas
    many times Cliplight Super Seal, it's everywhere available in town
    used once A/C Leak Freeze sample with success, but it's not available in town
  6. #45
    Jul 2005
    Tulsa
    thanks... got a R-22 system that's got persistent leak. have gone thru it in detail with H-10 and big blue. pumps down to 340 microns, holds 200 psi nitro for hours.
    traced problem to buried in concrete copper lines with no access. don't like it, but it's time for a sealer.
    will be giving Cliplight super seal a try...
