    Oct 2011
    midwest
    walk in freezer set up
    I got little bit of side work guys... Yea I am thinking about doing it for myself one day but I just dont have enough experience to do comerical refrigeration..
    I never installed walk in freezer or cooler. I have been doing service for about 3 year now but I never did a lot of work on freezer installs or coolers...
    Here is what I got
    Condesing unit on the roof already
    Fans are inside the box with evap.
    I do have most of my controls I just dont know how should i conect my evp fans... I have seen a lot of evap. fans in walk in cooler conected to seperate breaker not sure about freezers.. I would like to learn more about freezers and how to install them properly ... THANKS!
    Phoenix,AZ
    Evap fans are wired off your time clock.
    Oct 2011
    midwest
    ok, very good, thanx KB... So on what terminals should i put my evpa fans...
    Phoenix,AZ
    4. But, 1 leg of power is usually broken by a DFT fan delay switch.
    got a model # of the evap ?? then maybe you could find a wiring diagram floating around to reference also or even leave behind on site for a later time. once you get familiar enough with typical set ups you will remember
    Oct 2011
    midwest
    Quote Originally Posted by hvac wiz 79 View Post
    This is what I did today.. Thanks guys!
