Results 14 to 26 of 37
    Oct 2008
    Nashville ,TN
    H10pm is my make sure detector, I got the adapter that makes it 115v if battery dies.
    I have better luck with 410a with my d tek I think their both good detectors, h10 gets you pretty much to the spot, but sometimes having the longer wand makes it easier to get backside of coils with d tek select.
    Jul 2011
    Mt airy N.C.
    the new infacon tec-mate that i have seems to be holding up good, has been more accurate than the old fieldpiece i had before.
    up in the hizzy
    Quote Originally Posted by nacoomer View Post
    In the market for a leak detector. Recently purchased an Inficon Whisper but am very unhappy with it. Bought it since its ultrasonic but it wont pick up ANY leaks. had 2 that i missed that I found with a normal leak detector. Also liked that since its ultrasonic it will do gas but apparently it wont find any leak. anyone got an recommendations on a good leak detector?
    sorry you wasted your $$$ in the Whisper, pure junk, I tried one and returned it right away.
    read good reviews about the Tif ZX, bought one and love it, Johnstone sells it and if you dont like it,they take it back, the h-10 is a classic although is bulky and not very practical.
    Dec 2011
    louisiana
    leak detector recommendation
    Was hoping there would be more responces from more people. I am in the market for one also (have an old CPS 780 that says, yeh there is some loose freon, but cannot narrow down location, are there senors that can be updated?). My question is , is it worh buying an older used H10, like are there parts that wear out making it unreliable or is it better to get a new one (big$$), or one of the cheaper $100 -$200 other brand detectors? I know soap and bubbles ,but I really appreciate technology and my ears don't hear high pitch sounds anymore.
    Greg
    Mar 2012
    West Chester, PA
    Quote Originally Posted by Thomasg View Post
    The battery in my H10PM is dead. Where can i get that adapter? Otherwise it was a great leak detector and never steered me wrong.
    Oct 2008
    Nashville ,TN
    Ordered offline cant remember where,
    Ahead adapter
    E194707
    Hope that helps
    Btw my h10pm found a leak that me d tek select couldnt , kinda was upset so if you havent bought one go h10 or another.
    http://www.toolsource.com/battery-ch...rceid=googleps
    Ahead adapter
    E194707
    Hope that helps
    I've found this several times before.
    I'm at the point where I will no longer use the D-tek Select.
    Jul 2010
    Andalucia
    Them's fightin words, partner.
    There is NO difference between the H-10G and the H-10PM except for the battery.
    Both are incredibly sensitive and the H-10PM that I have has a sensor heat calibration feature that allows you to be 100% certain that the sensor is adjusted properly before you begin.
    Is the sensor and pump interchangeable between the two models?
    With Trump it is not like you are losing the presidency, you will be gaining a cable channel.
    If I win I will put Hilary in jail. If I lose, the system is rigged. Trump's banana republic USA 2016.
    Can't wait to see who is the first to say in 2020 we need to nominate a true conservative.
    Irish bookie already paying out on Hillary Clinton victory bets
    http://www.marketwatch.com/story/iri...ets-2016-10-18
    “I’ve said if Ivanka weren’t my daughter, perhaps I’d be dating her.” Donald Trump
    Nov 2010
    MN
    H-10PM
    Oct 2008
    Nashville ,TN
    Yea JP , I will be trying my h10 on small for 410a next time d tek officially back up now i just spent close to 400 to find out the hard way .
    Quote Originally Posted by pageyjim View Post
    The sensor is.
    I don't know about the pump.
    Apr 2002
    Western piedmont of Carolinas
    Just bought a new d-tek select as my old one was giving too many false possitives. Not sure yet if it will work any better, but something I did notice about the d-tek is it will not pu on weak concentrations of refrigerant. Added 1/4Lb R-22 and ran up 200psi w/nitro. Didn't pu a peep, pulled a vacuum and it started to leak down. Juiced up again w/nitro and found large leak at evap(mh quick connect) and one at the suction line at comp with soap.
    Quote Originally Posted by mlock
    Sorry you bought a Dtek.
    Best of luck to you.
