Results 1 to 13 of 37
    Mar 2010
    Leak detector recommendations?
    In the market for a leak detector. Recently purchased an Inficon Whisper but am very unhappy with it. Bought it since its ultrasonic but it wont pick up ANY leaks. had 2 that i missed that I found with a normal leak detector. Also liked that since its ultrasonic it will do gas but apparently it wont find any leak. anyone got an recommendations on a good leak detector?
    It depends on what refrigerants you're working with, but for most CFCs and HCFCs, H10G is as good as they come. I don't know how well it will work with HFCs such as R-134a and R-410a yet. Maybe someone who is in the know can chime in on that.
    The key to happiness is lower expectations.
    Don't pick the fly crap out of the pepper.
    Quote Originally Posted by Tech Rob View Post
    The H-10 is as good as they come.
    I was turning into a believer in the D-tek until recently when I had 2 of them miss 2 pretty large leaks.
    The H-10 found them immediately.
    It works on all refrigerants, but you have to turn the sensitivity up for HFCs
    Jan 2011
    Ward, Arkansas, United States
    I was looking at the D-TEK Select does anyone use that one and can comment on it's reliability? Will be used mostly on R410a and R22 residential and light commercial systems.
    H-10G, I gather there are multiple brands judging from googling...are you guys referring to any particular brand?
    "Gentlemen. You can't fight in here. This is the War Room!"-Dr. Strangelove (1964)
    Jan 2006
    McQueeney, Texas
    I'll always stick with the H10G.
    Johnson Controls, Penn, Yokogawa, Bacharach... They're all the same, I believe. Personally, I have a Bacharach version. Stay away from the H-10PM, though. I hear that one's a real P.O.S.
    Feb 2012
    Alabama
    Inficon compass has worked well for me.
    II Chronicles 7:14 Galatians 2:20 Ephesians 2:8-9
    Them's fightin words, partner.
    There is NO difference between the H-10G and the H-10PM except for the battery.
    Both are incredibly sensitive and the H-10PM that I have has a sensor heat calibration feature that allows you to be 100% certain that the sensor is adjusted properly before you begin.
    Oh, no. My mistake. It was actually the H-10X I was thinking of. I work with a guy who uses a PM... I have always wondered about the accuracy being dragged down as the batteries discharge. I wonder what kind of circuitry they have in place to prevent that?
    Jan 2011
    Well I ordered a couple of cheaper detectors off Johnstone today had an old reliable TIF break not long ago. We may step up to something better if these don't satisfy.
    Trying the Inficon Tek-Mate and TIF XL-1A
    Sep 2009
    Stumptown,USA
    Tif ZX-1 or H10.
    Challenge yourself, take the CM test --- Certificate Member since 2004 ---Join RSES ---the HVAC/R training authority ---www.rses.org
    I've not noticed a difference.
    Once the battery light comes on, shut it down, it's useless.
    las vegas
    dont give up on the ultrasonic. there is a learning curve to using
    an ultra sonic but when you master it it is a good unit.
    i use the vpe & have had real good success rate with it
