Results 14 to 22 of 22
Thread: Thread sealant
    Sep 2003
    Quote Originally Posted by n-e-w Jerz! View Post
    i despise that blue leak lock !!!! its garbage, it is overly used by techs that are overly confident in the product and not enough in their technique (in this case taking the time to make a good flare). the factory made flares on mini split line sets are not good enough for r410a systems, the install guys at my company use these and then us service techs have to go back and fix the problem! cut the damn tube with a good tubing cutter, ream the inside of the pipe carefully and oil the tip of your flaring tool before making a decent sized flare!!!!!
    i would use zoom spout oil over leak lock any day of the week!!!!!!
    you should use Nylog for all refrigerant threading, its the best product for the job!!!!
    Agree.
    Local 449?
    Jan 2001
    The leak was on a 1/4" mpt gauge fitting on end of canister drier. I put a compressor in october and found good leak blowing through leak lock. I know it wasnt leaking when I left as I am anal about leaks. where can I get nylog does united carry it thanks.
    leak lock sucks big time. its never easy trying to break free a nut when its in a tight spot with that sh!t ... im not a fan of it at all .. ive been using nylog for a while & like it
    Feb 2007
    Central NJ
    Quote Originally Posted by hvac17011 View Post
    UR or Johnstone
    You have to pay your due's before you pay the rent!
    Dec 2009
    Bristol NH
    410a is supposed to use a different flare than the standard.
    Particularly mini-splits.
    JP that's what all the trainers say but when pressed I have not found any to be other than 45* which is pretty standard. Years ago the LG guy was all about making sure everyone was using the special flaring tool he said 45* turns out that's the same as every flaring tool that we have all been using.
    And I never use the factory flares on the line sets it is only there to hold the nut on IMO.
    Jan 2001
    united says there is a different product for poe???
    Athens, Ohio
    There are two Nylogs. Blue for HFCs and Red for CFC/HCFCs.
    I like them.
    Feb 2007
    Central NJ
    Quote Originally Posted by kdean1 View Post
    I like them.
    though it does suggest here: http://www.refrigtech.com/Product/Se...nylog_red.html
    that is somewhat usable for POE lubricated systems.
    Athens, Ohio
    Why not just buy both and have full compatibility? They cost less than ten bucks each.
