Standing commercial freezer
Hello... Freezer not getting cold. Maybe low on R134a... With freezer on, Low side pressure 60 psig. Any suggestions?
you sure it's running? lol
Yeah... really.... if it is running doubt if it is pumping.
Maybe the OP can give us more details. Compressor information and amp draw, Model of the machine, high side pressure and so on.
Not to
But I am wiring up a refrigerator...
Does anyone know where I need to hook up this red wire?
Thanks in advance..!
dont worry about the red wires , theyre extra
Keep it simple to keep it cool!
Yes its running... Compressor and both fans are operating. I check the defrost timmer and it cuts off and cuts on the compressor. The liquid line leading into the evaporator is frosting up... but the temprature inside of freezer is about 58 F. I've charged the freezer once and it stayed cold for about 6mos. Any suggestions?
With a 60 psig suction pressure running R134A there shouldn't be frost anywhere. Check your gauges.
If you had to recharge it once before, I'd say it's low on charge again due to a leak...or possibly the capillary tube is plugged up.
A lot more info is needed to say much more than that.
Thanks... Will re-charge and check the cap tube.
Thanks... Will re-charge and check cap tube.
I wouldn't be messing with the charge until I found out why my pressure was so high.
Slow down there cowboy!
First, is it a cap tube?
Second, is there a receiver?
Third, has any one else been playing with the unit?
Fourth, is the discharge line warm where it goes into the condenser?
I r the king of the world!...or at least I get to stand on the roof and look down on the rest of yall
 Originally Posted by Phase Loss
Not to
Red wires can be attached to any wire UNLESS it's white or green.
60psi low side for a freezer? Maybe its 410a.
Will you be using a scale to do this ? How will you be checking the cap tube ?
- You may not post replies
- You may not edit your posts
Forum Rules
