    Mar 2012
    Hattiesburg, MS
    A/C running-air handler shut off-condenser continued to run
    Hello, new to the site, would appreciate any help. My A/C was running and then the air handler shut off but the condenser continued to run. The house was not cool (not a stuck contactor) and now the air handler wont come on. I am getting voltage on both sides of both transformers (its a gas furnace) and the only way to turn on the air handler is the switch on the handler. It is an older unit (no board), and the switch has 3 positions (ON, OFF, FAN). It would normally be in the ON position, but currently the only way the handler will turn on is in the FAN position. I am steadily checking different parts, t-stat is next, but if anyone can point me in the right direction that would be sweet.
    Phoenix,AZ
    Need more info! Like brand,model number and your occupation?
    Mar 2012
    Hattiesburg, MS
    I work in the fireworks business but am a universal certified technician thru Esco. Trying to do a little bit of this work on the side as it is somewhat seasonal and so is my job in fireworks. Its new to me though, so still have a lot of learning to do. The unit in question is the one at my house, not there right now, but will get the model # for you a bit later. Appreciate the help.
    In a boiler room
    Welcome here bigfleen.
    Worry is a really gross misuse of one's imagination. -- PHM
    Mar 2012
    Hattiesburg, MS
    Thanks buddy. Here it what Ive got:
    Nordyne
    MGHA-075ABFC-01
    In a boiler room
    If you repost in the Tech to Tech chat area you will get a lot more response.
