Results 1 to 9 of 9
    Jun 2008
    Jacksonville, Florida area
    Replacing Oil in Scroll
    Changing out one compressor in a 60 ton Trane Cold Generator, CGAFC604AAEA10000DE. The manual states to change the oil in the remaining compressor that is piped in parallel to the one I am replacing. What is the easiest way to empty the crankcase without cutting the other compressors piping apart too?
    Quote Originally Posted by Ancoma Tom View Post
    nitrogen
    ottawa canada
    Quote Originally Posted by jayguy View Post
    nitrogen
    Straws from your fave fast food joint are free , nitrogen is getting expensive
    HAHA
    Keep it simple to keep it cool!
    good old Europe
    On most compressors the oil charge connection and the dip tube inside do not reach fully to the bottom of the compressor. A lot of the s... remains there when you just push the oil out, using this connection. I use a vacuum flask with a small plastic hose and enter the compressor oil sump through the sight glass / oil equalisation line.
    "Quality exists, when the price is long forgotten."
    Henry Royce
    Not in Iran
    Quote Originally Posted by Entropie View Post
    Yep
    no signature blast'em man blast'em
    !!!KILL THE TERRORIST!!!
    Quote Originally Posted by Healey Nut View Post
    tasty!
    The Hot South
    What is a vacuum flask?
    good old Europe
    The guys working on absorbers do know them quite well (i don´t know how they call it). Its just a glass bottle (cylindrical or tapered) with a tapered (sealing) rubber plug on top. But it could be any other container who can withstand negative pressure (e.g. gas cylinder). With glass its just easier to monitor the liquid level inside.
    Henry Royce
