Results 1 to 13 of 34
Thread: High pressure
    Mar 2012
    Raleigh, NC
    High pressure
    Hey guys,
    I asked this question earlier but didn't really get an answer yet. I replaced an evaporator coil on a 3.5 ton carrier unit with a goodman coil, because the existing coil was rusted and leaking beyond repair. It came with a piston valve but after trying a couple different size pistons and still having high pressure, 320 psig, I switch to a txv. The pressure dropped a little bit, about 295, but I am still not able to get proper subcool temps. Also the pressure is still way high considering it's only 75 degrees, outside temp. I was only able to get 88 degrees or so on the high pressure side which means the subcool is way off. The superheat is within 15 degrees but I know with a txv subcool is what is important. Other than a restriction in the line, is there another possible cause? Of course I changed out the line drier when I installed the txv.
    In a machine room
    Did you evacuate? What Micron level did you achieve?
    It looks like you have over 40 SC. Start taking out Refrigerant until you get down to a more realistic SC.
    R22?
    Worry is a really gross misuse of one's imagination. -- PHM
    Mar 2012
    Raleigh, NC
    sub cool was 42. outside temp was 75
    In a machine room
    Quote Originally Posted by Cool Change View Post
    It's way overcharged.
    Mar 2012
    Raleigh, NC
    I will try that. yes, I evacuated, but had to do it the old fashioned way cause my micron gauge quite working and I am waiting for johnstone to get it back from the manufacturer. By the old fashioned way I mean vacuumed for 45 minutes, turned it off, waited fifteen and did it again. repeated
    Mar 2012
    Raleigh, NC
    thanks for the feed back chuck crj
    Mar 2012
    Raleigh, NC
    and yes, it is r22
    Jun 2011
    sfv california
    way overcharged txv is prob wide open and your just raising pressure was this at your house or customers
    May 2008
    Myrtle Creek. Oregon
    is the condensor clean? just a thuought.
    a stupid question is a question you wont to ask, but don't
    Virginia
    Quote Originally Posted by cboe View Post
    Ill bet not
    Mar 2012
    Raleigh, NC
    yes, the coil is clean. And Honestly I cant see y I would be overcharged. The factory charge is 5.4 pounds, plus a half ounce for every foot of line-set after 15 foot. 80 foot of line-set. That's 32.5 ounces. I know I started checking my subcool temps when I reached 6 pounds...
    Apr 2009
    Pan Handle, Fl
    Whats line set size? Need to charge with sc with txv. Bring it down to 10 and see what happens. Sounds like your over charged. Of course check the air flow and get it right.
    Insanity: Doing the same thing over and over again expecting a different outcome!
    Jul 2009
    South Carolina
    You said SH was around 15 but what was your suction pressure?
    Gary
    http://www.oceanhvac.com
    The best things in life are free but not everyone is willing to pay the price.
