Results 1 to 7 of 7
    DOA microchannel evap
    Puncture! Hisssssssssssssssss. Installers say they didn't do it, must have been factory damage. It was a cased coil.
    Apr 2001
    Over Here
    Here we go again!
    Feb 2012
    Opelousas La.
    Going to have to be careful not to drop a screwdriver on those coils when working on the blower.
    FL
    Thank you Mark.
    I have been wondering what to use on these new aluminum coils.
    I assume you have personally used dura fix? Is this the best way?
    NW burbs of Detroit
    mark beiser mark beiser is online now
    Professional Member*
    www.durafix.com
    Learn it, use it, love it.
    Your welcome.
    Good thing I got a lot of practice with a similar product from my domestic frig days.
    Manual defrost friges had exposed evap surfaces in freezer and they got punctured pretty regularly. So I used a lot of Aluma-Weld to patch 'em.
    You just hopped you got to em before they sucked in water....me and other guys were changing up to four FDs filled with water before we'd condemn the box.
    Quote Originally Posted by jvillehvac View Post
    Thank you Mark.
    I haven't used it to repair a leaking system yet, I just wanted to have something available for the inevitable.
    I first found out about it a couple of years ago while surfing YouTube videos on aluminum soldering, and was intrigued by a demo of it where a guy was able to solder 2 aluminum cans together with it, and patch some quite large holes in a regular coke can.
    I've tried it out on some pieces of aluminum tubing I cut off a scrap Trane condenser, as well as some small aluminum parts to test it out.
    The material, and its bond to the aluminum, are both stronger than the aluminum itself.
    The key, like with any aluminum soldering, is to get the surface as clean as possible, make a little puddle of the solder material, then scrub through the puddle with the SS brush to break up the oxidation layer to tin the raw aluminum surface with solder, otherwise you are just sticking it to the oxidation layer.
    The surface of raw aluminum oxidizes almost as fast as you can scrub the oxidation layer off of it, which is why soldering aluminum is "hard" to do.
    If you scrub make a small puddle of the solder, then scrub the aluminum through the puddle, the solder sticks to the raw aluminum before it can oxidize.
    with regular aluminum soldering, to cover anything larger than a tiny pinhole, you would have to tin the area being repaired with solder, and tin some solder onto a patch, then solder the patch over the area being repaired.
    With Durafix, you can bridge some fairly large holes with it, and once you get it to stick to the raw aluminum, you can build up the thickness as much as you want, and it is stronger than the base metal, so no need for the added patch.
    There are a ton of demonstration videos of it on YouTube.
