Results 1 to 13 of 18
Thread: Side entry A/H
    Tucson, Arizona
    Side entry A/H
    This can't work
    Oct 2008
    Coral Gables, Florida, United States
    Quote Originally Posted by shavedneon View Post
    This can't work
    unless its a slant coil.IMO
    Tucson, Arizona
    nope, that's an A coil.
    Northern California
    I've seen this b4, it can work for a while till the coil begins to build ice . Flip the coil around simple fix . If it was a Pane coil it would work just fine but it would not fit right.
    Feb 2012
    hyperion
    the trane hyperion air handler would work
    Dec 2010
    New Orleans
    How long was the system in place before they noticed a problem?
    Urbandale IA. USA
    Quote Originally Posted by subzerocool View Post
    Then ONLY half of the coil would be doing the cooling.
    just a thought
    Those who dance, appear insane to those who do not hear the music.
    Those who believe, appear ignorant to those who do not know God.
    NW AR
    That wont work in any position.
    Frederick, MD
    Not
    Quote Originally Posted by Alejandro Mart View Post
    necessarily. I saw a job with a slant coil where they cut the return on the wrong side of the slant. No air went through that coil either.
    GO NAVY, BEAT ARMY!
    A DECADE OF DOMINANCE! +3
    Here and there
    Comfort Specialist
    Mar 2012
    West Chester, PA
    some manufactures actually do allow for side resturn on their a coil units. It is not common and when it is permitted there are usually strict stipulations as to how much air may be introduced through a side return. This looks incorrect and if ice is building up, then it obviously is. Saddly this happens more often than you might want to think...
    Frederick, MD
    If
    Quote Originally Posted by ADillon View Post
    they do allow side return, it would have to be under the "A" coil so air enters through the bottom of it, not the side. As was mentioned, the Trane Hyperion would fit the bill.
    GO NAVY, BEAT ARMY!
    Jan 2006
    McQueeney, Texas
    That's really unbelievable!
