Results 1 to 1 of 1
03-20-2012, 04:08 PM #1
- Feb 2004
- swamps of jersey
- 104
Used Low Temp Vilter Compressor & Pumps
The following Equipment is available & in working condition, previously used in an ice rink with a R-22 system Call Andy @ (732) 477-4411:
(1) Vilter VMC 450XL Approximately 7 yrs old. SN#81586, R-22.
(2) Ideal 460, 3 Phase, 125 HP Motors. 1760 RPMs, Approximately 25 yrs old and have been re-built.
(2) B&G Pumps, 300 GPM, 208-230/460 3 Phase. (1) is used, size 1531, BF 7.5, 7.5 HP, 50' hd, 300 GPM. (1) New & Unused, size 1531, 3 BC, 7.5 HP, 50' hd, 300 GPM.
(1) 6" B&G Triple Duty Valve - used.
(1) 4" used "Y" Strainer
(2) Flex Connectors for pump, 6x4, 6x6.
(1) Used Condensor barrel, single pass 6" in/out. Mfg by standard refrigeration, p/n HSE125 - 2004.
(1) Non-Operational Frick Compressor (Bad Shaft). Model #MRI-90-8-FH-VBD, R-22, SN# 82004
ALSO AVAILABLE: 3 Storage Vessels, mfg by Frick, used for receiver tanks probably hold 1500lbs of refrigerant each.cant make this crap up
