Results 1 to 13 of 16
Thread: Stuck txv
    Mar 2010
    Chapel Hill, NC
    Stuck txv
    So in ac my high side pressures were pretty normal, but my low side was about 30 psi (410 a system). All my spider legs are freezing up and so I took the bulb off of the suction and put a wet towel on it then I went back up to my guages and my low side was still sitting on 30psi, not hunting at all. I diagnosed a stuck txv. Do you agree?
    Mar 2010
    Chapel Hill, NC
    wet, warm towel that is.
    NW burbs of Detroit
    sounds like to me
    Nov 2001
    east kansas
    Yes. When you purged your high side hose, was there a lot of liquid.
    Beware of advice given by some guy on the Internet.
    Mar 2010
    Chapel Hill, NC
    yeah there was actually. Tons. the remnants of what the evaporator was storving for I presume.
    Wichita Ks
    what was your subcooling?
    Mar 2010
    Chapel Hill, NC
    didn't check superheat or subcooling due to the fact that I couldn't get the txv to hunt. Probably should have but didn't. I can tell you that the high side was pretty much spot on for what Lennox said it should be.
    Wichita Ks
    your subcooling would have told you if you was stacking freon in the condenser or low on gas.
    NW burbs of Detroit
    Well, I would agree that while this is an obvious restriction based on the info you provided, a SH and SC check should always be performed.
    Mar 2010
    Chapel Hill, NC
    I agree. That is only the second stuck txv that I have come across and will remember to do a sh and sc check next time and will in fact do one on this unit before I begin the work of changing it. I would think that the superheat would be more important to the diognosis than the subcool, am I wrong?
    Ohio
    I always use a cup of warm water and ice water to see how the TXV reacts but I suppose a warm/ice cold wet towel would work and be a little bit easier to handle.
    Mar 2010
    Chapel Hill, NC
    Quote Originally Posted by freonrick View Post
    oh, right on. good point. Thanks.
    NW burbs of Detroit
    Quote Originally Posted by Bigdtown View Post
    No, the SC is most important in this case...the evap is going to be starved and SH will be high...
