Results 1 to 7 of 7
Thread: Dunham Bush
03-18-2012, 09:27 PM #1
- Sep 2011
- 12
Dunham Bush
Hello
I am in a service which is a unit Dunham Bush can support me with some information bulletins Service Manual appreciate any support ACHDX250 Model R-407C-6QP
Regards
03-18-2012, 09:54 PM #2
Get your post count up and become a verified pro member.
Read the rules about this not being a DIY site.UA LU189
10mm, because it's better than .45acp
03-21-2012, 07:26 AM #3
03-21-2012, 12:20 PM #4
- Sep 2011
- 12
Recently come to a service which has 1 unit Dunham bush which has damaged the 2 I have no Historal a compressor this unit can not find the manual for this unit HD1468641
Regards
03-24-2012, 09:54 AM #5
- Mar 2012
- Miami Florida
- 16
Man your spelling is horrible. The company I worked for the past 4 years was a DB dealer and I have worked on many of them. DX and Flooded but mostly flooded chillers with the vertical screw compressors.. That model number that you are giving out does not ring any bells. I guess that it might be a new system or a DX system that I have not seen. What is your problem anyways?
03-24-2012, 02:47 PM #6
04-10-2013, 07:27 AM #7
- Sep 2011
- 12
My English is horrible try to write less
2 units ACXI250 Dunham Bush no history
it recovers R-407 4 systems
Leak check
Vacuum to 500 microns
charging by weight R-407
Sistemas #1 136 kgs
Sistemas #2 164 kgs
Amper Plate
Sistem #1 180 Amps
Siatem #2 214 amps
Cutting points high at 370 psi for 30 psi low
Change for High Low 50 psi 320 psi
System 1 leader compressors
Pressure differential in water at 10 psi
Program
LV WTR SP A=45 B=0.8
Lead A= 2.0 B=1.0
Ramp Up A=0.4 B=30.0
Pulse WTH A=20.0 B=1.0
Dead Band A=5.0 B=3.0
Working
54°F LVT 60°F
C1 Succ 70 psi Des 261 psi
C2 Succ 85 psi Des 275 psi
Superheat 8°F sub cooling 9°F
Temp Amb 75°F all fans operating both systems
C1 Desc Temp 165°F
C2 Desc Temp 155°F
Ampers Measured
Sistema #1 166 amp
Sistema #2 190 amp
I searched newsletters manuals compressors for loading and unloading de slide
Both the units of the system 2 will not exceed 15% FLCP systems 1 to 100% in FLCP
Question
That is the FLCP???
Would have to operate at 100% both FLCP??
I have to make a change in program for 100% load FLCP systems # 2?
Will pressure drop graphs for this unit and review appropriate galonajes
I appreciate your comments Regards
blast'em man blast'em
