03-27-2012, 04:46 AM #1
New Guest
- Mar 2012
- 2
TALOR,SOFTSERVE,FREEZINGINTHEHOPPER
142-12MODEL FREEZING HOPPER, ADJUSTED TEMP BUT STILL FREEZING, CHANGED BOARD & PROBE SAME PROBLEM
03-27-2012, 05:16 PM #2
New Guest
- Mar 2012
- 2
ANY POSSIBLE IDEA
03-27-2012, 07:28 PM #3
- Sep 2011
- Augusta, ME
- 69
Customer using a different brand product or anything different in the product being used recently by any chance? Just trying to think outside the box haha
03-27-2012, 08:39 PM #4
- Jan 2008
- Jackson, MI
- 111
In that model 1 compressor handles both the hopper and barrel. Is refrigerant leaking past a closed solenoid valve or is the valve stuck/coil voltage not dropping out.
03-28-2012, 10:46 PM #5
- Dec 2010
- Duluth MN
- 22
Check the scraper blades for excessive wear. Also check to make sure the screw is spinning inside. Just because the pully is spinning does not mean screw is. the berings can be junk, you can check by how much play you have on the pully.You can also take the machine apart and check buy putting the drive coupler( I think thats what it is called) in and spin the pully. The coupler should spin if it doesent the bering is blown up. Good luck
