Results 1 to 12 of 12
    just breathe . . .
    I'm certain ill be replacing the cap tube & dumping the oil in due time. i don't think it was ever cleaned due to extremely poor accessibility.
    Sent from my HTC Sensation 4G using Tapatalk
    that little box is going to die now; and it's all your fault
    NW burbs of Detroit
    Refer was a kick for me to do...except for THAT
    Dec 2010
    Woodbridge Twp, NJ
    I do a lot of those bev-air milk cooler chests. As if the fact that the condenser sucks up dirt wasnt bad enough, they drop the condenser below the rear cover. You know, just incase there was some dust bunnies that would normally be missed.
    Every customer you take for granted today will be someone else's tomorrow.
    Jul 2011
    Mt airy N.C.
    I might be an idot but with a dirty con. why will you need to replace the cap tube??
    The condensing temperature will run high enough to cause the oil to clog/ restrict the cap tube, "burn out" the oil in the compressor due to lack of refrigerant return causing high superheat there by killing compressor. When compressor is changed and driers installed and vacuum completed, then refrigerant weighed in, you will soon discover why change cap tube. AARG
    Saddle Up!
    "hey while your here" ..... upon first glance of the fan guards i knew i was in for some tlc on the coil. pic #2 is what i pulled off with the wire brush. hot water via a hose easily cleaned the evap after but the drain pan & line was a b!tch. took pics of the evap but you couldn't tell what was what the flash sucked & lighting was weak
    Oct 2011
    Chicagoland Area
    Quote Originally Posted by dandyme View Post
    Ain't that the truth
    Nov 2001
    Seattle, WA
    Is this in a factory that specializes in producing lint? Sooooooo this is where clothes dryer lint is made!
    - Alexis de Toqueville, 1835
    Afton, VA / Khorat, Thailand
    Apparently right here.....just need a straight razor......
    Midnight Sun Astrophotography
    I've changed more cap tubes in the last five years than in the previous thirty five. How much enviromental damage have we done with our larger truck payloads to carry at least 4 extra refrigerants, recovery equipment,to do service work created by people saving the world, Not to mention the pollution load created manufacturing distributing and installing equipment designed to fail faster.When R22 was causing failures in low temp applications the industry responded with R502. When are we going to find an oil that worksin the real world.
    Apr 2012
    preventative maintenance!
