Page 1 of 7 1234567 LastLast
Results 1 to 13 of 87
    north suburbs of Chicago
    Stay bright 8 or hard stick?
    Time to beat this dead horse again maybe. I keep reading so many posts from guys using nitrogen and brazing and have been long before I installed my first 401a. I was reassured by many people and sources that with correct techniques Stay Brite 8 was more than adequate. We all know brazing with a stick can cover up a multitude of sins.
    I think I'll stick with Stay Brite but just curious of others views. Why especially are you uncomfortable using Stay Brite 8?
    NW burbs of Detroit
    because it is not endorsed by any mfg i know of. that might just be a COYA...cause what i have seen of stay-brite, it works well. don't know about the hi-side cause even back in the day when all i did was refer there were guys using it for soldering the discharge line to the comp, even tho the specs said not to.
    time will tell.
    It doesn't matter that Stay Brite 8 is "more than adequate", pretty much every manufacturers installation instructions specify brazing the refrigerant line connections, thus making it required per the mechanical codes.
    Having said that, I keep some on my truck and occasionally use it on heat sensitive repairs.
    The main practical issue I have with it vs brazing is that it has very limited gap filling ability, so you need a tighter joint than is often possible with the play dough copper stubs on a lot of equipment and service parts these days.
    Oct 2009
    new jersey
    I have only used it on rotolok valves.
    Feb 2012
    Toronto Canada
    What is this stuff?
    This is confusing me?? Is it a type of solder rod? You can use it instead of running Nitro when you weld?
    Can someone please post a link to what it is your Talking about?
    Quote Originally Posted by #1CDNTECH View Post
    What is this stuff?
    I can't think of any link. You use it the same way you use any roll solder and flux.
    NW AR
    I use 15% sil fos on everything, even steel to copper. Its all I need with the work that I do.
    Atlanta GA area
    Highlited above is more or less what I do also. If I am attaching a TXV... I probably will pull out the StayBrite. If I am attaching an AC or a coil (and there is adequate tubing between the TXV and end), probably will use dynaflow (my preferred brazing stick).
    GA-HVAC-Tech
    Nov 2007
    Sherman, TX
    http://www.harrisproductsgroup.com/e...y-Brite-8.aspx
    Here are the tech specs.
    It is more than adequate for use with R410A.
    Installation instructions recommend brazing.
    The last time I looked in the code book, it was not approved. Why, I couldn't tell you. Look at the tech specs. It is plenty good enough from a technical standpoint.
    Using Sta-Brite #8 requires clean, good fitting joints.....which is what we should be doing anyway.
    I've seen more than my share of crap sil-fos work.....like people sticking a 3/4 suction line into a 7/8 fitting on a condensing unit.....then pinching it shut and "buttering it up".....You can get away with murder with sil-fos as far as the quality of your joints goes....
    Technical incompetence is NOT a sales tool....
    Sep 2003
    I thought the real reason was the use of flux when using staybrite and the potential harm it could do to a 410A system
    Quote Originally Posted by ar_hvac_man View Post
    Brazing alloys containing phosphorous should not be used with ferrous metals.
    You end up with a brittle joint that is prone to cracking, hence the reason every manufacturer of brazing materials recommends against using it on ferrous metals.
    http://www.harrisproductsgroup.com/~...ler_Metal.ashx
    "Stay Silv 15 is not recommended for brazing steel or other ferrous metals."
    http://www.silfos.com/htmdocs/produc...w_to_info.html
    "However, when brazing copper to steel (in compressor or valve assemblies) you can't use phosphorus bearing filler metals as they form brittle phosphides and the joint could fail. Instead use a phosphorus-free filler metal"
    Dec 2011
    bedford ind
    Quote Originally Posted by John Markl View Post
    I've seen it but not used it. Are you saying you use it even when it is against code?
    Nov 2007
    Sherman, TX
    Quote Originally Posted by ironpit View Post
    Did I say that?
