Results 14 to 26 of 30
    Jul 2011
    East coast USA
    Quote Originally Posted by coolerik View Post
    really, whats the worst thing that could happen..comp will trip overload or the breaker...worse case your comp will plow the internall relief or if its a bigger system blow the relief and there goes a few hundred lbs.....doubt its gonna hurt anyone not like jumpin a limit on a gas fired appliance
    still not reccomended by me, but i doubt its gonna hurt anyone
    maybe not physically hurt someone, but if a service provider jump out a safety and my unit blew up. That vendor would buy my a new unit. regardless of the age of the unit, the hurt comes from not having a job or a bad rep.
    My advice, record everything, do it right and inform the customer, if you cant fix it before you leave lock it out or pull the fuses
  2. Likes DirtyHamilton liked this post
  3. #15
    Quote Originally Posted by Chris_Worthington View Post
    How long does it take to add a tee and another switch anyways? What about 10 minutes? The cost for equals? not much.....
    And the strange thing is. The customer will pay you to do that.
  4. Likes DirtyHamilton liked this post
  5. #16
    Feb 2012
    Nebraska
    CF motor failing and the high side wasn't elevated?
    Fan was eventually going out on overload. The maintenance guy would notice it and reset high pressure and walk away. When I pulled the motor all of the oil was leaked our of it.
  6. #17
    Nov 2011
    St. Louis
    Assuming the old has no schrader core, add an access tee with a core depressor, attach switch and call it done
    As others have said that is a call you need to make, supply houses are generally open the next day here
    No schrader? Holy crap...this is why it pays to hang out here!
    Anyone have a picture of this tee handy?
  7. #18
    Mount Airy, MD
    Here ya be http://www.rsd.net/search/item.php?i...=JB+A31851-100
  8. #19
    Nov 2011
    St. Louis
    Thank you.
  9. #20
    Mar 2015
    Medford, N.Y.
    I use them so often that I carry 8 (2 of 4 diff types) of them in my regular tool box.
  10. #21
    Aug 2009
    Beatrice, NE
    It is my understanding that any safety switch by law can not have a valve in line to isolate it from the system, thus no core in the schrader fitting. Having said that I have seen cores in on some systems.
  11. #22
    Southold, NY
    Quote Originally Posted by TechmanTerry View Post
    Quote Originally Posted by BNME8EZ View Post
    This thread is almost 6 years old!
  12. #23
    Jan 2010
    And the code is only for the hi pressure safety I do believe.
  13. #24
    Nov 2011
    St. Louis
    I was a young lad.
    Is the Religious Right to blame for Christianity's decline?
    They argued that, as the Religious Right became increasingly visible and militant, it became associated with Christianity itself. And if being a Christian meant being associated with the likes of Jerry Falwell, many people—especially political moderates and liberals—decided to simply stop identifying as Christians altogether.
    http://www.theamericanconservative.c...nitys-decline/
  14. #25
    Apr 2005
    Australia : Queensland
    https://www.actrol.com.au/product/re...a31851-2712482
    The primary function of the design engineer is to make things difficult for the fabricator and impossible for the serviceman.
  15. #26
    Apr 2005
    Manitowoc didn’t have a Core in their Fan Cycle Control & if performing warranty works they would not cover the cost of Refrigerant to replace the Fan Cycle. They stipulated a Pinch Off Tooll must be used.
    https://imperial-tools.com/products/...inch-off-tool/
