How can i test my new digital manometer
Dual digital, supco DDM55.. and want to try it out.. now nothing in my apartment is gas
anyone have and ideas. i was thinking of a slight pressure of nitrogen. it can convert to psi,inch h2o etc.
You can't kiss death without it kissing you back. Death is a passionate kisser.
Be careful with Nitrogen. That manometer probably will only read a psi or two.. You don't want to bust your new tool.
Better Ideal. Drill a home in the supply and return duct of your air handler. Measure the TESP and see how much CFM's your moving!
Gotta have the right tool for the job!
Where is all the stuff MADE IN THE USA?
"Thats what we do Troy. Incredible, Invisible, Imbelivable things. We are an Unseen, Unknown, Unvincible fraternity of craftsman.."
ahh yes never though of it. ill be right back
static pressure tips?
Did you use those static pressure tips (see link below)?
Anyone use them reliably for ESP?
http://www.trutechtools.com/Dwyer-Ma...Tip_p_629.html
 Originally Posted by hurtinhvac
nope i dont have those, i wonder how much it affects the accuracy.
http://www.fieldpiece.com/manometers/sdmn5
RMA316 Manometer Adapter
Used for 5/16" pressure outlet ports.
does anyone know if i can pick up some stuff at lowes to make this same outfit ?
that size pressure port seems to be used alot of cooking equipment stuff. my meter uses the 1/8" barbs not the 3/16"s it comes with
Lowes sells brass fittings for gas pressure testing..
http://www.trutechtools.com/TruTech-...it-_p_630.html
I own a Testo 510 and bought a kit similar to this except it came with some tubing..
I recommend the static Tips. They work great and will last forever..
I have a similer kit from Tru Tech, but didn't immediately see how the supplied tubing (1/8 ") would work even with the little coupler. I'll make a trip to Lowes I guess.
- You may not post replies
- You may not edit your posts
Forum Rules
