Results 1 to 13 of 37
Thread: Refrigerant Stop Leak
03-16-2012, 09:19 AM #1
New Guest
- Oct 2007
- 2
I replaced a compressor in a 7.5 ton Carrier roof top unit on a restaurant recently. It went well and the unit runs fine. I went back a few days later to check things out and found a big oil spot on the condensing coil. It looks like a pretty good leak. This unit is 10 years old and in hind sight I shoud have probably just replaced the unit. But it seemed pretty sound.
I feel bad for the owner since he spent his good money after bad equipment.
My question is, this refrigerant stop leak. Does it work ?
I think if I could get him through this summer, he'd replace the unit next year. The coil is leaking around the galvanized end plates. So it can't be fixed.
Thanks.
03-16-2012, 09:22 AM #2
banned by Admin
- Dec 2010
- New Orleans
- 1,012
Do not use stop leak, it ought to be called stop compressor. You can fix a leak around the galvanized just cut it out very carefully and use low heat, but make sure you know exactly where the leak is.
03-16-2012, 09:32 AM #3
- Feb 2012
- EVERYWHERE
- 161
03-16-2012, 10:30 AM #4
banned by Admin
- Dec 2010
- New Orleans
- 1,012
03-16-2012, 11:18 AM #5
Dont do it or youll be changing that compressor again
03-16-2012, 11:28 AM #6
03-16-2012, 11:49 AM #7
03-16-2012, 12:47 PM #8
03-16-2012, 05:19 PM #9
- Nov 2004
- Western NY
- 943
I have used it twice on older McQuay heat pumps and haven't had any problems, it seals the leaks for good. I get it from united.
http://www.nucalgon.com/assets/prodlit/3-52.pdf
03-17-2012, 12:09 PM #10
- Jan 2012
- ohio
- 120
how would you braze galvanized? would you use silver solder or soft solder?i have never done it before thanks
03-17-2012, 12:56 PM #11
U dont braze the galvanized, you carefully cut it out and silfos the leak... time comsuming but better than putting glue in the system and distroying the whole unit
03-17-2012, 12:58 PM #12
03-17-2012, 01:53 PM #13
Don't use stop leak. It's only approved if you are a 'home warranty servicer'.
I have great results with this stuff concerning your situation. I use needle nose pliers to remove the aluminum fin material (3" x 3" square or larger) around the area of the leak, then braze the copper tube and galvanized together, encapsulating the leak. Watch your heat - the copper tubing is thin, and the galvanized will not accept the brazing if it is 'cherried' (overheated) for too long.
I have done this many many times with great results. Do not breathe the fumes from the galvanized or it will make you sick - very sick.
This beats trying to cut the galv away from the tubing, as it always gets damaged, then you have to cut it and 'sleeve' it with 1/2". Unless you prefer to spend a long time cussing on a 'temporary' repair.
