Results 1 to 13 of 37
    Mar 2011
    Probably one of the most dangerous things I've seen.
    I honestly could not believe it when I opened up the panel to find this.
    At least you can use the clips as a disconnect.
    Oct 2011
    midwest
    I would not touch this! lol
    Jan 2011
    Boston, MA
    Wow, they could have at least made it look nice.
    Mar 2011
    Meter Pulled, new disconnect to be installed tomorrow. Unbelieveable the things you run into out there. On top of that the homeowner told be its been like that for a year on a home with a 200 amp service.
    Virginia
    Wow, it really makes you wonder how people that do this can sleep at night.
    When you do a job, Always make it easier for the next guy, because you may be the next guy working on it.
    SE Michigan
    Whats the problem?....its only single phase 230 VAC.
    “Socialism is a philosophy of failure, the creed of ignorance, and the gospel of envy, its inherent virtue is the equal sharing of misery.”
    Apr 2011
    Wonder about the voltage drop across those clamps......
    Feb 2012
    Toronto Canada
    It's been grounded what more can you ask for?
    Shhh some people
    Atlanta GA area
    Quote Originally Posted by Dad View Post
    They could have at least sprayed for spiders. Ghezzzz
    Look at the magic smoke footprint on the right leg. Wonder what took out the breaker.
    The previous unit that was also installed by a Craig's list guy...
    GA-HVAC-Tech
    Oct 2011
    between here and over there
    If it ain't broke, don't fix it haha
    Afton, VA / Khorat, Thailand
    I know it's tempting to do that last bong hit before work in the morning.......but next time, wait until lunch.........think of the children!
    Midnight Sun Astrophotography
    Mar 2011
    This is on the main disconnect at the service pole on a manufactured home. This isnt just for the HVAC, its for the whole home. Not to mention someone moved a new home with a 200 amp service in, and just used the 100 amp wire. Everything about this job is wrong and dangerous.
