Results 14 to 17 of 17
    Jan 2010
    Toronto,Ontario Canada
    float switch?
    Umm where would you mount it? in the blower section? im in Canada not sure if that is even being considered here. any pics?
    Jul 2002
    SE Texas
    Quote Originally Posted by ascj View Post
    How is that even accomplished on the smaller RTU's?
    Alot of the pans are just as wide as the coil and tight against them.
    Attachment 251771They don't hold up, but they're enough to get the inspector off our backs.
    in a house, Appomattox, Va.
    I did two last summer, existing units that the lines had stopped up. But they had an 1 1/2" on the pan to put it on, used a bulldog float switch.
    Don't see an easy way to fix one with 1/2" gap by pan, and don't think wet switch would work in base pan of unit.
    Hard way would be to put second sheet metal pan under main pan and put switch on that.
    Col 3:23
    Dec 2010
    Florida
    Try an Aquaguard AG 3180E
    Get them from Totaline
