Results 1 to 13 of 35
Thread: Replace evaporator coil
03-15-2012, 05:15 PM #1
- Mar 2012
- Raleigh, NC
- 34
Hi guys,
Im new in the industry and new on this site.
I installed an evaporator coil in an upflow unit. After charging with a few pound of r22 and turned on the ac to start doing superheat and subcool reading to adjust the freon levels I noticed a hissing sound near the line drier I installed about 4 feet from the air handler. The unit was holding pressure when I tested when I pressure tested with nitrogen and I maintained pressure in the gauges so I am sure it is not a leak. I am wondering if I got too much solder in the line and that is causing an obstruction in my attempt to make sure I had good joints. Tell me what you think
03-15-2012, 05:21 PM #2
Professional Member*
- Aug 2007
- Northern VA 38 degrees N by 76 degrees W
- 3,251
03-15-2012, 05:23 PM #3
I think that would be an awful lot of solder if you have a restriction it should show up on your gauges
Sent from my PC36100 using Tapatalk
03-15-2012, 05:24 PM #4
- Mar 2012
- Raleigh, NC
- 34
Not sure, was just thinking maybe some dripped into the pipe. I pushed a lot in there. Was reaching I guess because I didn't know any other reason there would be a hissing sound other than a leak which it is not.
03-15-2012, 05:25 PM #5
- Jan 2010
- 64
If you have a restriction you would notice a temperature drop across the drier not to mention probably see something in your pressures superheat and subcooling.
Sent from my SPH-D710 using Tapatalk
03-15-2012, 05:25 PM #6
- Mar 2012
- Raleigh, NC
- 34
I probably used a quater stick
03-15-2012, 05:27 PM #7
- Mar 2012
- Raleigh, NC
- 34
I had to shut it down for the day but I was getting only 45 pounds on the low and about 80 degrees before I left so I was very confused
03-15-2012, 05:28 PM #8
- Aug 2011
- sherman tx
- 27
try pressuring the unit back up and soap bubble your weld joints
03-15-2012, 05:29 PM #9
03-15-2012, 05:30 PM #10
- Mar 2012
- Raleigh, NC
- 34
Ok, I will again. I did hold 100 pounds of nitrogen and soap bubbled the joint before adding freon
03-15-2012, 05:33 PM #11
- Mar 2012
- Raleigh, NC
- 34
you should only need as much as it takes to wrap around the pipe
Yes I know your right about that but since it was my first time soldering since school and my first real job I was a little paranoid and jammed a lot in there
03-15-2012, 05:33 PM #12
- Jan 2010
- 64
80 pipe temp
03-15-2012, 05:34 PM #13
- Mar 2012
- Raleigh, NC
- 34
Do you have any other ideas on the hissing sound
