    May 2003
    Sarasota. Fl
    Need a 65,000 BTU Split System
    I have a home with a 13 year old Carrier split. (Heat Pump)
    Outdoor is an 060, indoor has an 070 in the model #.
    Load Calculation comes out to 65,600 BTU's.
    Cant find a match with Trane, Rheem or ComfortMaker.
    Anyone know if any manufactures have a single phase, heat pump, 5.5 ton? If so an ARI # or model numbers would be great.
    I cant split the duct work and add a second system. Its not in their budget and the home is for sale.
    Thanks for any help.
    It is the job of thinking people not to be on the side of the executioners.
    ~Albert Camus
    Dec 2010
    New Orleans
    It is not a perfect world, Go with the five ton tell them to buy a electric heater if they get a little chilly. JMO
    In a split, best cooling I could find is Lennox HPX14-060 or XP14-060, they can reach 61K.
    Massachusetts
    Are you using Manual 'S' for the equipment selection? If the SHR # isn't the default .7, you may come close with a 5.0-ton unit, properly charged with proper airflow. Or maybe your calc is off just a tad? What's in the house now? You can get higher outputs from geo systems but it doesn't sound like an option from your post.
    Quote Originally Posted by miami mike View Post
    Make improvements to lower load and decrease equipment size.
    May 2003
    Sarasota. Fl
    That is what I'm going to do. It has R19 batts in the attic. Going to do some blown in fiberglass and get it up to R30.
    Thanks to everyone that replied!
    ~Albert Camus
