Results 1 to 10 of 10
Thread: valve bandit
03-13-2012, 10:19 PM #1
- Jul 2011
- Mt airy N.C.
- 44
valve bandit
This is the third unit i have serviced that is missing the service valves and ports. This is an old intertherm not the best unit in the world but they can take abuse pretty good.
i have found out who is doing this. i thought it was just a one man operation but it turns out to be one of the big name bis. around here. LOL thanks to them i now have a new customer.
03-13-2012, 10:28 PM #2
- Nov 2011
- Phoenix,AZ
- 96
That's weird I replaced a unit that didnt have any recently I had to recover instead of pumping down
03-13-2012, 10:37 PM #3
- Aug 2008
- 212
Most of those old Intertherm Mobile Home units had the Quick Connect Connections. They did not have service valves. When they start leaking you have to cut them out and re-pipe. Looks like they forgot to give you a high side port on that one.
03-13-2012, 10:38 PM #4
If the valves where leaking and the unit is old and customer is cheap and is in need of cooling. Why is this so wrong if two service ports are welded in at time of vlave replacement. I do not see what is so bad.
Maybe I am wrong ????
03-13-2012, 10:41 PM #5
- Jul 2011
- Mt airy N.C.
- 44
yep i forgot you are right they did have the quick connect. bugs the he!! out of me
03-14-2012, 12:17 AM #6
So after they were done brazing the copper back together after removing the valves, how did they re-charge the unit or better yet, how did they pull a vacuum?
03-14-2012, 12:24 AM #7
I had to do this once. It was a fire job. the insurance company wasnt going to pay for new valves or unit(go figure). so i removed both service valves(they leaked) brazed in a tee with shraider port on both lines.
03-14-2012, 09:37 AM #8
- Jul 2011
- Mt airy N.C.
- 44
the only way that they could add freon was through perm. suction. pulling a vac on the unit if they did it at all could not have been acheeved correctely.
03-14-2012, 09:41 AM #9
- Jul 2011
- Mt airy N.C.
- 44
at least you added ports. i see nothing wrong with that
03-14-2012, 11:22 AM #10
It would be easy to remove the service valves, add a ball valve on the LL and brazed in schrader valves on suction and liquid. You can still pump down and all then.
I r the king of the world!...or at least I get to stand on the roof and look down on the rest of yall
