Results 14 to 26 of 26
    Apr 2001
    Originally posted by leedesert
    ... I just want to make sure the most used appliance in my house is done right.
    I've got news for you, you're not going to get it "done right" by sizing it on the internet. Anyone who doesn't get a load calc done, especially with HPs, is a fool.
    Monmouth Junction-NJ-USA
    If you didn't plan on taking the advice of people who have done this for a living for decades, why did you bother to ask?? Keep asking around and sooner you will hear the answer you want to hear. LOL
    If you really know how it works, you have an execellent chance of fixin' er up!
    Tomorrow is promised to no one...
    Sep 2001
    richmond,va.
    Cool
    Again I recommend asking your contractor for the load calculation. We as a group do want to help. Better to be mad at your contractor than the people on this web site. If you have to check-up on your contractor sounds like you have the wrong contractor. I don't think anyone is getting any residuals from recommending Hvac-Calc. I use it and it works.
    Jan 2002
    ok, I'll contact my builder to get the load calculations. I'm sorry if I got a bit short but Charlie's comment rubbed me the wrong way.
    I guess what I'm looking for is if the size match sounds close to correct. I know you can't be exact but I don't want to waist a lot of time and irritate my contractor with having to look up information like this if everything is ok. I'm reconsidering buying that program on my credit card so don't think your advice is not heard. Thanks for your inputs, even those I didn't like.
    Sep 2001
    richmond,va.
    Cool
    We understand your situation. Let us know how everything turns out. Enjoy your new home.
    Oct 2001
    The problem here, which no one has explained fully, is that we can not possibly even guess closely with the information you have given us here. If your house is a typical construction, located in Oklahoma, with no shade, on the south west side of a hill, two four-ton units may or may not do it, (I have 5 tons on 2400 sq ft) depending on how much glass is present, how much insulation in ceiling and walls, what kind of windows and doors, vinyl siding or brick, how many occupants in house, what setting do you like your cooling set on, do you have attic ventilation (power or natural?)
    On the other hand, if your home is located in Wisconsin, and of any recent vintage, 4 tons is over sized. There are W-A-Y too many variables for anyone here to make a semi-accurate guess.
    Now, to address the other problem here. When someone shows up at your front door, or calls you on the phone, and asks you a question, you can't help but wonder why they want to know. So, you base your response on the EXACT wording of their question, and the attitude with which they asked it. Most of the guys on this web site are contractors. You began your question by saying,
    " I'm checking up on my contractor so I want to make sure the heat pump is proper tonage. "
    You might as well have said, "I don't trust contractors, you all lie and steal, so tell me if my contractor is lying or stealing." No, that is not what you said, that's what most people here heard you say. Then, to add injury to (perceived) insult, you refuse to spend $40 to perform a load calculation that would be accurate and remove all your doubts. The man who created HVAC-Calc owns this web site, and pays the considerable fees involved in hosting and moderating a web site this size. He is, by default, the only advertiser. But, we don't get paid for selling you the product. If we did not believe it was; by far, the greatest product of it's kind on the market, we'd give you some other advice.
    So, as a design engineer, what is it I'm trying to say? Download the program, and by this time tomorrow, you'll not only know exactly what your load should be, you'll understand why your load is that much (or that little) and where changes to your home might benefit you most.
    Sorry if we came across a little strong, we just perceived that you came across that way. If you'd like to give us some more information about the details I mentioned, someone here can make a semi-close guess at your load, but it's still only a guess.
    Goodluck with your house. Let us know what you decide to do.
    Hindsight is NOT a plan!
    Nov 2000
    Memphis TN USA
    The first step is check your contractors refferences. If he seems like a duck, he is probably a duck. If he has done good work for your friends and people you trust he will do good work for you. Don't buy the program if you don't want. Many people get a good feeling from getting in on their own job. The peace of mind from doing the relatively easy calculations yourself, is worth $40. AC systems cost a good deal of money, peace of mind is priceless.
    Jan 2002
    Bama,
    Thank you for your reply. I guess I did chose bad wording when I opened this thread. If it's any consolation, I downloaded the trial and will probably activate it today.
    The installer is a reputable Trane rep. in this area so I'm sure he does good work but I have found area's where his worker's have gotten shoddy. Several ducts had large gaps between the wall and rim of the duct behind the actual vent cover. The air would have blown into the wall there but I got them to fix it. They also failed to seal a hole cut out in the downstairs air return box. They used some black rubber like filler but it oozed out of the hole. I opened the air return grate and removed the filter to look inside and the insulation is hanging from the attached outer wall. Once the system turned on I would have had fiber glass particles blowing through the house.
    Anyway, these are the things that have prompted me to question their workmanship.
    Oct 2001
    There you go!
    Now, that's the information that would make it understandable for you to question him. Good for you that you watch and keep an eye out.
    In his defense, most companies I have worked for a person whose job it is to go behind the crews and look for just the sort of things you have found yourself. Keep watching, and stay involved. Good job on downloading the program, now you'll know for sure. And, HVAC-Calc has the best one-on-one help desk you've ever experienced, so if you have questions, ask.
    Keep us up to date,
    BC
    Jun 2001
    New Jersey
    Leedesert: Sorry if I came on a little strong. From reading your other thread, Am I correct this is a new home being built? I, now can understand your concern and being nervous.
    They probably put a builder's grade in your home. You have to request that upgrade.
    The architect or builder should have did a heat/cool load on your home. I am glad to see you doing your own load calculation. Sometimes they are undersized, especially the homes in my area.
    Hope you do well!!!!!!!!!!!!
    Nov 2000
    Memphis TN USA
    If I were having a house built, I would check up on the contractor's work too. You did not pick that contractor, your builder did. Your builder might have picked the best in town then offered him less money than he ussually gets. In new construction many corners are cut. You stay on top of them, and you will get a better house. Take a box of donuts out the the workers several times and you will get a better house. Try to look like them when you go out there. A suit will not get the workmen on your side. A pair of jeans will allow the men to think they can relate to you better. There was a privite home inspector that used to come around jobs that I was on. The builder did not know if he was a sub or not. He talked to us during breaks and bought us ice cream and gatoraid when the ice cream truck came around the job site (I bet they sell more ice cream at construction sites then playgrounds.) His clients got better houses because he found problem when there was still time to fix them.
    Good luck with your new house. They do build them like they used to if you can make them.
    Jan 2002
    Talking
    Well Gentlemen, the numbers are in.
    I went through the program and after getting some guidance from HVAC Calc's help line I've come to this conclusion. My system is fine.
    The HVAC program says my Heat Gain is 30,507BTUH (2.5 Tons)and my heat loss is 25,647BTUH.
    The system that was installed has two units. Each (upsatirs and downstairs) has a 2 ton heat pump for a total of 4 tons for the house.
    The gentlemen who helped me from HVAC Calc said that I'm fortunate that they installed a dual zone system as standard. He said that more than likely my upstairs will do most of the work in the summer since the cool air travels down the open stairway. The opposite will happen in the winter.
    He also said it was better to have two 2Ton units than one 3Ton unit covering the whole house.
    Anyway, I gave you all that so I can say thanks. I kinda got off to a wrong start but I think you all have changed over time.
    [Edited by leedesert on 01-30-2002 at 01:29 PM]
    Jun 2001
    New Jersey
    Thumbs up
    Glad to see everything worked out for you. You are lucky, Two systems are not standard in NJ area, they are upgrades. You will be happier and the systems will be more efficient.
    You sound confident and pleased. Great!Enjoy your new home and keep those filters clean.
Comfortech Show Promo Image
Comfortech365 Virtual Event
