Results 14 to 26 of 27
    I'm sorry - I didn't write what I meant
    I should have written Pressure Drop.
    The refrigerant flow moves through the metering device at a rate based on the size of the orifice and the difference in pressure across it. As the Pressure Drop reduces - so does the flow rate. This reduces the refrigerating effect and is why head pressure must be controlled to maintain a certain minimum Pressure Difference. Typically you would be OK using 100 lbs. as a minimum number.
    Sorry about that - I am becoming a dullard apparently.
    PHM
    Quote Originally Posted by twophase View Post
    interesting. I was experimenting with a small r134 system I scrapped from a mini fridge (without losing the charge, total PITA...urethane insulation everywhere!), and it behaved like it was low on charge (frost line shrinks back on evap and temp drops) when the condensor coils were submerged in ice water. I don't have any service ports on it yet, so wasn't able to find out what would happen if gas was added.
    Oh sorry, but what does TD stand for?
    But yeah, it kind of looks like I'll be pumping salt water for this project if those kind of temps are possible. On the plus side, it will simplify the analysis, won't kill us on cost, and will leave more time for homework. I think the refrigeration system will take a bit too much testing and development to achieve in a month, and if someone else finds out that salt water works, we're screwed unless we build a really killer system.
    Really it will now come down to simply minimizing cooled mass and maximizing insulation and liquid flow. The ice is just bagged ice from 7 eleven, so there's lots of surface area.
    I do want to mock up a refrigeration circuit anyway just to learn more about it and what would have been possible. I'm a very hands on type and really like building stuff. Moulding a custom chiller vat out of great stuff only goes so far, lol.
    PHM
    Aug 2011
    Northern VA
    PHM
    Ok, thanks. The question stirring around in my mind now is why can't you just shorten the cap tube/widen the orifice to restore flow to suit the lower pressure difference? Basicly tune the system for the desired evap temp for a given pressure drop? Does the refrigeration cycle just not work properly without enough pressure difference?
    Seems to me that the flow rate would reduce with a reducion in pressure drop if the case was trying to empty out a refrigerant tank passively, but the flow rate, at least in the academic sense of the term, for a pumped fluid is more a function of restriction and the pump (compressor) flow rate versus head pressure curve, right? Reduced restriction should actually increase flow, right? Maybe 50 psi just isn't enough to make the refrigerant change phase correctly?
    Chicago, IL
    I can guarantee there will be teams using salt. If youre lucky they will be using table salt (NaCl) which had a higher brine temperature than alternatives such as CaCl. You may be able to find somthing with even better ice melting properties. Your biggest challenge is going to be transferring heat through the bottle, especially since Dasani bottles are relatively thick and they are smooth compared to the ridges on other brands that increase surface area. Definitly do something to agitate the bottle to make some circulation inside. Can you remove the label?
    Jul 2000
    Guayaquil, EC
    Is fabricating your own 500 ml "bottle" from copper within the rules?
    Aug 2011
    Northern VA
    No, the bottle must be exactly as it comes from the store, except maybe the label. I'll have to ask about that.
    I'll
    Unfortunately, now that it occurs to me, I don't know if i'll be able to find ice melt now that it's so warm out. Probably nobody has it on the shelves anymore. I wonder if glycol automotive antifreeze would work the same way. Maybe epsom salts would work well, too. The circulation system will be designed for as high a flow as practical, and the inlet/outlet will be oriented to create a swirl to increase convection on the outside as well as to impart random rotational motion of the bottle to increase convection inside as well.
    Jul 2000
    Guayaquil, EC
    You would benefit from rigging up an agitation system for the bottle...to create internal turbulence like a washing machine...for enhanced heat transfer.
    With the bottle immersed in your circulating brine, suspend the bottle by the cap, spin it in one direction for a couple of seconds, then reverse and repeat.
    That should be worth some points ...at least for creativity.
    Chicago, IL
    I don't think glycol would work well. It has a few properties make it not ideal for this application. The most serious (and unusual) is that its lowest freezing point is at 70% concentration. If you increase or decrease the concentration the freezing point rises quickly. Since melting ice will be continually diluting the solution you will have trouble maintaing a low freezing point. I'm also unsure of whether or not glycol is good at melting ice, or just preventing it from forming.
    With salt, mixing the proper concentration is easy. Just put in ton of it. You want to add as much salt as the water will hold in solution, and then add a bunch more so you have undissolved salt circulating with the water. As the ice melts, additional salt will dissolve to keep the brine at the strongest possible level
    If you can't find ice melt on at the hardware store, you could try calling up a snow plow company. Im sure they should have some lying around.
    alternatively:
    http://www.amazon.com/Pellets-CPP50-...1850330&sr=8-3
    $60 for 50LBS with free shipping
    California
    It may sound crazy.
    But are you allowed to boil the bottle of water?
    It has something to do with the boiled water displacing oxygen molecules. the displaced oxygen will allow the water to freeze faster than room temperature water.
    It's called the Mpemba effect.
    The agitated bottled water experiencing the Mpemba effect with the swirl of brine around it should drop temp nicely.
    Mar 2001
    Ilwaco, Washington
    Calcium chloride available through concrete companies
    One way to outthink people is to make them think you think. They'll think you're not really thinking what you're trying to get them to think you think...........
    Feb 2012
    Toronto Canada
    What type of schooling is this project for? This is to get a refridgeration lic or cert ??
    Aug 2011
    Northern VA
    No, it's junior year undergrad engineering.
    The official test bottles are provided on testing day, so no chance of boiling. I'll have to see what kind of salt I can get my hands on and test to see what works the best.
    Thanks for the ideas.
    Jul 2000
    Guayaquil, EC
    http://www.walmart.com/ip/Morton-Ice...-4-lb/10318347
    Aug 2011
    Northern VA
    Thanks for that. I found some at the grocery store. Didn't know there was such a thing. It doesn't say what kind of salt it is, though.
