Results 1 to 9 of 9
    McQuay Service Tools
    Hi, Does anyone know where I can get a copy of McQuay service tools for Microtech II. I'm trying to change IP address's of a bunch of self-contained vertical McQuay AHU's. I need the service tool for this right? BTW it's the older model Microtech (not the white one). Any insight is appreciated, as I am trying to integrate to FX40. I scanned the AHU's and know there IP's, but I need to change the ip's because we are adding the bms to customer LAN for remote access.
    Thanks.
    Home of the newly wed and the nearly dead
    I got mine from the class at the factory in Minneapolis. You might be able to purchase it from your local McQuay rep that handles applied rooftops and air-cooled chillers. The McQuay factory service branch here deals mostly with water-cooled equipment.
    Truth is still truth, even if no one believes it. A lie is still a lie, even if everyone believes it.
    "It's called the american dream because you have to be asleep to believe it" -George Carlin
    "A nation of sheep begets a government of wolves" -Edward R. Murrow
    "I have problems just like you. One time, my dancing horse almost fell into my car elevator" -Mitt Romney
    Buy american made goods & support locally owned businesses!
    okay, so what I'm asking now, is this what is needed to change the ip address of mcquay units?
    South Florida
    Here you go
    If it looks like a Johnson Controls N30 with about 2 inches added all the way around this is what you will need. The software conflicts with Project Builder for N30s if you have it on the same computer.
    http://www.mcquay.com/mcquay/common/...type=MicroTech II&topic=Controls&subtopic=MicroTech® II Controls
    I recall having to swap out some Microtech 2 BacNet interfaces for LON interfaces, and I had to set up the MAC address using ServiceTools and by changing the dip-switches on the BacNet interface before removing the old interface. Not sure about the IP address, or even what protocol the FX40 uses.
    Quote Originally Posted by metasystech View Post
    Sorry that link doesn't work.
    **update** in case any one ever needs to know, ip can only be changed with service tools, which must be ordered thru McQuay. Just ordered a copy. Thanks for the replies.
    South Florida
    The software is Free
    Sorry the link did not work. Here are directions to find it on the site for free. Go to Mcquay.com Then click on the following products>controls>Microtech II Controls>Application Software Last One at the bottom "Service Tools V2.4" its Free
    San Diego, CA
    Here's the corrected link
    Jan 2012
    Nj
    I thought you had to buy the full tool and software from Mcquay and whats on the website is the free updates?
