Page 1 of 4 1234 LastLast
Results 1 to 13 of 45
    Sep 2010
    miami,fl.
    r-22 with poe oil
    i went on a service call. compressor shorted out. found contactor welded closed. compressor was under warranty. need to replace comp. but my question was i noticed this bad comp said poe oil and its was running r-22. Is that ok. i thought r-22 had mineral oil in it and you dont want to mix oils or it can form acid? any input. or links i can learn more about refrigerants and oil mixtures
    Moved thread to tech to tech chat.
    Feb 2012
    EVERYWHERE
    Quote Originally Posted by anthonyac1 View Post
    R22 does not have oil in it when you buy it. The unit has poe or mineral in it.R22 works fine with poe.I would use poe if the unit calls for it. Just do not mix poe and mineral or it will gum up and cause a lot of issues.
    Oct 2005
    B.C. Canada
    As far as I understand POE is compatable with anything....doesnt mean i like it though!
    Nov 2007
    Sherman, TX
    Lots of racks out there, running R-22 and POE.
    If it was bad news, Copeland wouldn't be manufacturing compressors for R-22 service and shipping them with POE oil.
    Technical incompetence is NOT a sales tool....
    Apr 2003
    Maple Grove, MN
    Compressor manufacturers are using POE in more and more of it's compressors. This is something you will need to check when you are replacing a compressor. I ran into this issue last week. I was replacing a bad compressor on a R22 walk in cooler and decided to get an entire new condensing unit. Right before I brazed everything up, I noticed where it said it had POE on the compressor. I was pretty pissed, but happy I didn't braze it up yet. I was able to return it and get one that had mineral oil in it like the original.
    It would be easier if they could just ship the compressors dry and then maybe include a couple of different bottles of oil so we could pick which one we wanted. Either that, or design some type of universal oil that will mix with everything and not suck so bad. I don't expect this to happen any time soon, though.
    May 2003
    Utah
    Mineral oil decomposition due to extreme discharge temperatures is a definite problem in LT R-22 systems. One advantage of POE over mineral oil in R-22 low temperature applications is that it is more stable at the elevated temperatures occurring in these systems.
    British Columbia, Canada
    Quote Originally Posted by coolerik View Post
    Nope, NOT compatible with R-12.
    Southold, NY
    Quote Originally Posted by koolkahuna View Post
    Thats a new one on me.
    Care to explain?
    Will do, right after this call is completed...
    Sorry, I typed that in wrong.
    What I meant was that you can't mix R-12, POE, and Tequila.
    Apparently I just had a mini-stroke/brain fart...not sure what I was thinking.
    POE IS compatible with all refrigerants according to literature I could find.
    Actually, I was told by several suppliers, and other techs that R-12 was the only refrigerant not compatible with POE. As I never charge a system with R-12 anymore, I took their word for it.
    Don't I look like the tool...
    My Apologies!
    Nov 2007
    Sherman, TX
    Care to explain?
    I have seen charts that say not to use R-12 with POE. Dunno why though.
    Confused
    I thought I had too...almost a Matrix moment for me trying to find backup for my statement that R-12 wasn't compatible with POE, what I thought was true is all of a sudden not?
    I gotta go check the back of my neck for a cable plug in now...
