Page 1 of 6 123456 LastLast
Results 1 to 13 of 75
    Microchannel evap
    They're here!
    Nordyne C7 coils. This should be interesting. They say they've tested extensively and they will drain fine.
    Feb 2012
    Nebraska
    May drain, but how will they clean? I hope filters get changed with those!
    Tallahassee, FL
    Nordyne says they clean easier because you can use a brush and not damage the fins.
    I also think it interesting how the refrigerant feeds the lower right of coil and suction is from lower left header. Interesting.
    Feb 2012
    Opelousas La.
    I'm not a fan of the micro channel coils. I have found many leaks in the condenser coils(mostly coleman trailer condensers). Time will tell.
    Florida's space coast
    Changed one out about a month ago on a 3 ton heat pump.
    Seems to be well made.
    We've been doing so much,for so long,with so little, that now we can do almost anything, with nothing at all.
    Cincinnati, Oh
    neat stuff. Now if only they can make them smaller somehow.....
    "Just get it done son."
    Dad adjusted
    Not many evaps are decent sized anymore except maybe 3rd party coils then you wonder what you are really getting.
    NW AR
    Cool, first one ive seen.
    Yorks condensers are done that way now but not the h pumps yet. Drainage.
    Loris SC
    I've been seeing these come out on commercial ref. condensing units. I haven't had any issues with them but I bet they'll be a pain to fix leaks on them.
    NW AR
    I was told they had a repair kit but it didnt work out so now theyre just replacing the condenser.
    Jan 2005
    where it's nice and warm
    My question is. How can an expansion feed into a header and still feed may be twenty or more tubes equally.
    Jul 2009
    Columbia, MD
    just more complicated things for the not so trained people to work on.
    Cincinnati, Oh
    Quote Originally Posted by ararams View Post
    Experimental Research and CFD Simulation on
    Microchannel Evaporator Header to Improve Heat
    Exchanger Efficiency
    "Obviously, the single inlet header concentratedly distributes refrigerant into middle portion of microchannel
    coil; the dual inlet header significantly improves the refrigerant distribution uniformity inside inlet coil header; and
    the distributor inlet header performs the most uniformed refrigerant distribution."
    http://docs.lib.purdue.edu/cgi/viewc...0evaporator%22
    Page 7.
    And, it appears these microchannel coils feed on one end of the header, not the middle, which clearly wasn't even considered acceptable enough to be tested in that study.
    Read the conclusions also. They highly suggest uniform distribution, for maximizing efficiency.
    Keeping in mind, thats from 06.
    I wonder if there is something INSIDE the header that acts as a distributer.
    Dad adjusted
