Results 1 to 9 of 9
Thread: What causes it?
    Mar 2012
    My house is in Texas..
    What causes it?
    Unit = MarvAir
    Problem = no evap blower running..
    This unit has humidistat and ambient lockout....
    I noticed blower came back on..internal lockout ..... Pulling 7 amps rated for 4.3.
    All coils are clean and filter off.
    Volt - 208.
    Visually see one winding discolored.
    Replaced motor and amps were 4.3. (still kinda high but I thought @ 208 it's ok).
    New motor is doing the same.....
    Cap is ok
    Oh... It's on a VFD house ....
    My thoughts are a loss in voltage sometime in the night.
    "Duct tape is like the force. It has a light side, a dark side, and it holds the world together."
    Jan 2012
    Did you check tension and alignment on belt?
    Mar 2012
    Direct drive
    East of big city prices.
    Did you get an OEM motor? Does it have and duct work on it?
    Mar 2012
    Yeah ... It was ordered from manufacturer. And no duct .. Just a boot ...
    Oct 2008
    Motor Is More Than Likely Overloaded, Moving Too Much cfm,Try Opening EconomIzer If Equipped Or gOing To Medium Static, Also Check Relay operation
    Nov 2001
    Seattle, WA
    MarvAir is typically a commercial/industrial unit. Is this a wall hang unit? And is the new blower pulling over amps too? I'm not clear on what you are saying. And what is a VFD house?
    Just guesting from your limited info is the unit is receiving low voltage. Check all wiring including the power inputs when the unit is running. If fine then check all the wiring going to the blower motor when running checking the voltage for any voltage drop.
    - Alexis de Toqueville, 1835
    Mar 2009
    Mid-Mo
    So it was rated for 4.3 and the new one is pulling 4.3... I'm kinda confused. We have lost a fair amount of blower motors on our critical units that run a lot, it happens.
    Mar 2012
    Drilling rig house.... variable speed drive house.... Low voltage.
