Results 1 to 13 of 17
    Mar 2012
    Carrier furnace - strong odor from outside vent when running
    good afternoon,
    I have a mid 90's Carrier furnace that in recent weeks the smell coming from the outside vent while its running has become strong and smells like combustion and a bit of propane like smell. I can feel the intake beside it pulling in air and both vents are clear. Its always had a smell when its first started up outside - but this smell seems to now continue outside whenever its running.
    All 3 visible burners seem to fire quickly and well when it starts up, and as far as I know the water seems to be draining out ok into the floor drain.
    No smell or CO is detected in the house or around the furnace, but I'm concerned about this smell as I'm wondering if its not burning properly.
    Any idea what may be causing this issue? Could it be a heat exchanger?
    Thank you.
    Athens, Ohio
    No need to wonder - it's NOT burning properly. Numerous things could be the cause. The heat exchanger is not the likely cause since you do not smell anything in the house. CO is odorless but other combustion byproducts have odors. It is time for you to call in a pro with a combustion analyzer to find out what is causing this potentially dangerous behavior.
    Carrier 90? I'm gonna vote plugged secondary.
    Mar 2012
    Quote Originally Posted by kdean1 View Post
    Thanks - I've shut it down until someone has a look. I'm interested to know what it could be.
    Mar 2012
    Yes its a Carrier 9200.
    So why would it smell outside and not inside?
    butler pa
    brown/black inside furnace exhaust ?? sulphur/putrid exhaust smell ??
    usually failing/plugged secondary hx
    Mar 2012
    Don't see any discoloration but definitely a bad smell outside.
    Is there any warranty on those parts ?think i t's just under 20 yrs so getting to the point if it's a crazy repair might just replace.
    Thanks again.
    Should have heat exchanger warranty but the wisest move is to replace at that age.
    Aug 2000
    Central Oregon
    My vote goes to low propane level. Only because I had service calls within a week of each other with the same problem and same solution.
    If you think our goverment is screwed up. You haven't lived in another country.
    Mar 2012
    This is a natural gas furnace but the exhaust smells propane like.
    Athens, Ohio
    I hope the serviceman will also confirm that the gas pipe is big enough.
    I had a service call a few years ago where the installing company used 30' of 3/8" O.D. copper tubing to feed a 100K Btu LP furnace. The secondary was plugged so badly that the burners melted the lens on the burner cover. The furnace was just under 10 years old.
    Oct 2006
    The Beach
    Please get it checked as soon as possible. Could be a danger to you and your family. Very possible the secondary stopped up.
    Blue Fox
    Jul 2009
    Ontario, Canada
    more than likely plugged secondary heat exchanger. I would advise not using that furnace until its checked. Do not inhale the exhaust fumes outdoors--carbon monoxide levels will be extremely high there.
    Had a case a few weeks ago, same as you described. Homeowners carbon monoxide detector was going off. Get there, and the roll out switch tripped, had a melted sight glass, and carbon monoxide level were over 5000+ppm in the exhaust.
    It should be covered under manufacturer's warranty, but not the labor. But as BaldLoonie mentioned, may be in best interest to replace furnace instead.
    Let us know what happens.....
