Results 14 to 22 of 22
    Southeastern Pa
    Quote Originally Posted by ironpit View Post
    I've seen an example of it. Just don't remember where.
    When you remember, send as much info as you can to NFPA.
    2 Tim 3:16-17
    Member, IAEI
    AOP Forum Rules:
    Dec 2011
    bedford ind
    I will be glad too. It seems it had something to do with lightening charging a gas line then duct work.
    Southeastern Pa
    Was the ductwork bonded to the system grounding electrode?
    2 Tim 3:16-17
    Member, IAEI
    AOP Forum Rules:
    Dec 2011
    bedford ind
    I don't remember, but it seems like we were talking about bonding and grounding csst. I'm trying to remember. I'll call my son-in-law tomorrow to see if he remembers. It may have been a csst booklet I read.
    Southeastern Pa
    There WAS an issue with CSST and the need for bonding due to a perforation in the steel caused by a lightning strike.
    2 Tim 3:16-17
    Member, IAEI
    AOP Forum Rules:
    Dec 2011
    bedford ind
    Ralph morrison touches on the topic in his book Grounding and shielding/circuits and interference.
    Jan 2001
    Quote Originally Posted by Glennhvac View Post
    We are allowed to run about 5 feet of flex. Anything else has to be HARD pipe and hand insulated. I think to prevent fumes when the house is burning to the ground.
    Man... I remember the pre flex days..... I bet people today would just die if they had to run hard pipe off the trunk to the registers in an attic today.
    Or a bad crawl space.
    north suburbs of Chicago
    Quote Originally Posted by corny View Post
    Old days? That is what is required again now in all the areas I work in. Insulated hard duct. I had one job where they wanted a second system installed in the attic for a/c only. I figured the hard pipe and insulating it all by hand added probably 20 hours to the job or more plus the material extra cost.
    Dec 2011
    bedford ind
    Confused
    couldn't find the info I was looking for, but did find some material in Tru-flex metal hose corp. installation training guide, that states, and I quote
    "Even a nearby lightening strike that does not strike a structure directly can cause metallic systems (such as wiring, piping and ductwork) in the structure to become energized.If those systems are not properly bonded, the difference in potential between the systems may cause the charge to arc from one system to another and cause damage to to csst. End Quote.
    Which makes me wonder about the bonding and grounding of the complete system , especially if vibration dampening legs are used on the furnace.Not all furnaces I have seen installed have ground wire.
    Also if csst requires # 6 ground, I'm rethinking how a metal duct system should be bonded or grounded, or if it should be.
