Results 1 to 13 of 22
    Dec 2011
    bedford ind
    foil flex and electrical code
    Does foil flex touching 12/2 or 10/2nm wiring constitute a violation of the electrical code?
    Cincinnati, Oh
    Quote Originally Posted by ironpit View Post
    If it does, it's none that I've ever heard, or enforced.
    You should see some of the apartments I do. The sofits are so small, our flex (silver foil) touches wire almost all the way from the panel, to the outlets.
    "Just get it done son."
    Dad adjusted
    Dec 2011
    bedford ind
    i haven't been tagged on it yet, but I aways take pain to keep it two inches or more away. Electricians who come behind always run there wire against it.
    Cincinnati, Oh
    Whats going on, that made you think about this?
    Dad adjusted
    Dec 2011
    bedford ind
    A conversation with my son-in-law. He is a union electrician and a very good one at that. I didn't think to ask him at the time, but thought about "clearance to metallic objects" later. By the way, I like most of your postsYou seem very good.
    Cincinnati, Oh
    Well thank you sir!
    I would have thought that clearance to metal is related more toward metal framing, or things that could cut and tear the exterior PVC sheathing on the romex. Which is why I use MC on all commercial jobs.
    What your son in law WILL run into, if he hasn't already, is physical touching of romex wire (or any other plastic), to Blazemaster (orange sprinker piping).
    They (Code council, or whoever writes this junk) have decided that the plastic in blazemaster will deteriorate if it comes in contact will any type of other plastic related material.
    We ran black plastic flex in that particular set of appartments, and we had to get a letter from the manufacturer of the flex, showing that they had done testing related to blazemaster, and that it was allowed to "touch".
    A large project (the banks project here in cinci) actually saw deteriation of blazemaster, at the point of contact.
    Dad adjusted
    north suburbs of Chicago
    I wish we could still even run flex here! What a nightmare those changes caused for attic jobs.
    Cincinnati, Oh
    Quote Originally Posted by Glennhvac View Post
    ....what!?!
    Dad adjusted
    Dec 2011
    bedford ind
    I was thinking about shorts or induced voltage that might occur from nearby lightening strikes.I've seen where lightening has induced voltage in wiring and jumped to metal duct.
    Quote Originally Posted by hvacvegas View Post
    ....what!?!
    We are allowed to run about 5 feet of flex. Anything else has to be HARD pipe and hand insulated. I think to prevent fumes when the house is burning to the ground.
    Southeastern Pa
    I think that a magnetic field strength that is sufficient to induce a voltage from a lightning strike would be so close to the building that the induced voltage would be the least of the effects.
    2 Tim 3:16-17
    Member, IAEI
    AOP Forum Rules:
    Southeastern Pa
    The only code provision that I can think of is that the wiring must be protected from damage. I doubt that contact with flex duct is likely to cause damage to NM cable.
    2 Tim 3:16-17
    Member, IAEI
    AOP Forum Rules:
    Dec 2011
    bedford ind
    I've seen an example of it. Just don't remember where.
