Results 1 to 13 of 16
03-10-2012, 10:27 AM #1
- May 2008
- IN/KY Area
- 28
Looking to stock refrigeration parts
I run a HVAC/R supply house and want to increase my inventory with the right refrigeration parts. I have access to all of the major brands, i.e. Ranco, Johnson Controls, etc. I want to make sure that I have the right parts in stock for most service calls for my customers. Can anyone supply me with a list of the most common parts that are used for refrigeration? Maybe your truck stock list? Manufacturer brand and model numbers will be greatly appreciated. Thanks.
03-10-2012, 11:01 AM #2
- Mar 2006
- 950
defrost timers/ grasslin and paragon
dual pressure controls/ johnson controls
thermostat/ johnson controls (i prefer the one with the coil built ontop of the unit)
fan delay, defrost termination switchs
3in one (supco, 1/2hp)They told me to use the brain God gave me.
I did.
Now I'm an Atheist. Ironic, isn't it?
03-10-2012, 11:24 AM #3
- May 2008
- IN/KY Area
- 28
03-10-2012, 12:19 PM #4
03-10-2012, 01:15 PM #5
That Paragon 8245-20 must be a typo. Did you mean 8145-20?
I also stock:
Paragon 4001-00 Timeclock
Ranco A12-700, A12-701 Constant Cut-in Temp Control
Ranco 010-1483 Low Pressure Control
Full Line of 330V Start Capacitors
Mars/Steveco Potential Relays
Evaporator Fan Motors - 1/15th HP 1550 RPM (115 & 230V) (CW & CCW)
Various Copeland & Tecumseh Condenser Fan Motors
Unit Bearing Fan Motors - 5W 115V CW, 9W 115V CW and 16W, 35W and 50W in 115 & 230V, CW & CCW
Sporlan Filter-Driers - 3 cu in through 30 cu in (Flare & Sweat)
Sporlan C032-CAP-T
Sporlan SA Sightglasses - 1/4" through 5/8" (Flare FM & Sweat)
Supco BC-1, BC-2 & BC-3 Capillary Tubes
There's more, but I can't recall them off the top of my head.
03-10-2012, 01:20 PM #6
- Aug 2011
- Indiana
- 53
Copeland / Tecumseh current relays and motor protectors for the smaller compressors..
Sent from my iPad using Tapatalk HD"The Elite Brotherhood of Guys Who Fix Air Conditioners" - Community (NBC)
03-10-2012, 08:25 PM #7
- May 2008
- IN/KY Area
- 28
03-10-2012, 08:30 PM #8
Keep a list of what you have to order in or what a customer calls and requests.
I'll make a few other suggestions.
Buy a Sporlan Q and BQ case. This will allow you to build a wide variety of TXVs at a moment's notice.
Stock a variety of refrigerants. Refrigeration work takes more than green and pink cans.
03-10-2012, 08:37 PM #9
I usually keep at least 2 of those Acme 100 motor kits in my truck. Little things like acid tests and acid scavenger for POE. Refrigeration stems (i call 'em pigtails, i dont know what you guys call em).
Do you stock any parts for ice machines? If so, which brands? I think we can definitely give you a good list for those.Every customer you take for granted today will be someone else's tomorrow.
03-10-2012, 08:41 PM #10
03-10-2012, 09:09 PM #11
You don't need to ask your customers what they think you should stock...
If you think about this...they are already telling you.
Just look at what parts you order vs the parts that you don't order.
and THIS will tell you exactly whats going on in your market area.
03-11-2012, 12:00 AM #12
- May 2008
- IN/KY Area
- 28
03-11-2012, 12:04 AM #13
- May 2008
- IN/KY Area
- 28
The problem is that none of my predecessors have ever ventured outside of selling equipment from the single brand that we sell. This has made us non-existent for 90% of our market. I've been able to grow most other areas of the business in the last year and now I want to become established for the reefer guys. There's less competition in this area than the HVAC side of the business.
