Results 27 to 39 of 49
  1. #27
    Oct 2011
    Las Vegas, NV
    Agreed, very good information. Thanks for posting that.
    Sent from my PG86100 using Tapatalk
  2. #28
    Feb 2012
    Atlanta, Ga
    anybody use the starter pow-are-paks with any problems?
  3. #29
    Jun 2011
    Houston area
    Red face
    Quote Originally Posted by gravity View Post
    .......2. loose wires on the peckerhead.......
    I resemble that remark and find it highly offensive.
    The picture in my avatar is of the Houston Ship Channel and was taken from my backyard. I like to sit outside and slap mosquitos while watching countless supertankers, barges and cargo ships of every shape and size carry all sorts of deadly toxins to and fro. It's really beautiful at times.....just don't eat the three eyed fish....
    LMAOSHMSFOAIDMT
  4. #30
    Southeastern Pa
    Quote Originally Posted by Glennhvac View Post
    Yeah if I can find them near me! Plus I guess they are not advised for scrolls so that is another issue.
    I think the "not advised" wording is a little misleading.
    What the scroll guys are saying is that because a scroll starts basically unloaded, there should be no need for a start assist device. However, there are times when one is indeed indicated. The scroll motor is electrically identical to a recip motor. Only the method of compression is the difference when it comes to loading on startup.
    2 Tim 3:16-17
    Member, IAEI
    AOP Forum Rules:
  5. #31
    north suburbs of Chicago
    I admit some ignorance on the internal mechanics of the scroll compared to a recip. I think what I gather by 'unloaded' is that they can and will start easier than a recip under the non equalized pressures you find so often with the new txv coils?
  6. #32
    Sep 2009
    Stumptown,USA
    There are a lot of informative videos on youtube, just search refrigeration compressors. I also like the 5-2-1.
    Challenge yourself, take the CM test --- Certificate Member since 2004 ---Join RSES ---the HVAC/R training authority ---www.rses.org
  7. #33
    Southeastern Pa
    It's a smoother, more gradual start because the scrolls take several revolutions to build a pressure that is greater than the discharge line pressure, whereas a recip builds that pressure in a stroke or two of the pistons, which is often one or two revolutions, so the load on the recip motor is much steeper from rest to running at RLA.
    2 Tim 3:16-17
    Member, IAEI
    AOP Forum Rules:
  8. #34
    Thanks for all the feedback , help and advice. I really had not heard of those 3-2-1 kits and hope to find a parts place around me that handles them. I also hope there is enough room in these downsized control sections to install them.
  9. #35
    The internal pressures on the pumping mechanism in a scroll compressor equalize nearly instantly when it turns off because there are no discharge or suction valves to prevent it.
    There is a check valve in the discharge outlet of the compressor shell to prevent the system pressures from equalizing through the compressor, but there is no pressure difference across the actual pumping mechanism, so scroll compressor always start fully unloaded.
    TI really had not heard of those 3-2-1 kits
    "5-2-1"
  10. #36
    "5-2-1"
    Today was good! I learned this. Thanks
  11. #37
    Dec 2010
    Palm Beach,Fl.
    Another 5-2-1 Convert here. No more kickstart for me. Still use OEM kits for Trane stuff whenever possible though
    Quote Originally Posted by k-fridge View Post
    The laws of physics know no brand names.
  12. #38
    Saint Augustine, Florida, United States
    so I meter the start caps when diagnosing and find some of them bad, I sometimes reuse the existing pot relay and just change the cap. Keep some in my van. Usually the relay is still good. Anyone object to this, I am talking about getting a compressor up and running when it just won't start.......meter goes up and then down on a start cap, I crimp a terminal end on the resistor and reconnect to the terminal when done. What would happen if the resistor was left unattached?
  13. #39
    Jun 2002
    south jersey
    I guess I will be throwing away all my super boost. Great thread. This is why I am here every day. Very informative. Thanks for all the info gentleman.
