Results 27 to 39 of 49
Thread: Hard start kit opinions.
03-10-2012, 01:52 AM #27
Professional Member*
- Oct 2011
- Las Vegas, NV
- 347
Agreed, very good information. Thanks for posting that.
Sent from my PG86100 using Tapatalk
03-10-2012, 05:35 AM #28
- Feb 2012
- Atlanta, Ga
- 20
anybody use the starter pow-are-paks with any problems?
03-10-2012, 06:58 AM #29
The picture in my avatar is of the Houston Ship Channel and was taken from my backyard. I like to sit outside and slap mosquitos while watching countless supertankers, barges and cargo ships of every shape and size carry all sorts of deadly toxins to and fro. It's really beautiful at times.....just don't eat the three eyed fish....
LMAOSHMSFOAIDMT
03-10-2012, 08:46 AM #30
I think the "not advised" wording is a little misleading.
What the scroll guys are saying is that because a scroll starts basically unloaded, there should be no need for a start assist device. However, there are times when one is indeed indicated. The scroll motor is electrically identical to a recip motor. Only the method of compression is the difference when it comes to loading on startup.[Avatar photo from a Florida training accident. Everyone walked away.]
2 Tim 3:16-17
RSES Certificate Member
AOP Forum Rules:
03-10-2012, 09:22 AM #31
03-10-2012, 10:06 AM #32
There are a lot of informative videos on youtube, just search refrigeration compressors. I also like the 5-2-1.
Challenge yourself, take the CM test --- Certificate Member since 2004 ---Join RSES ---the HVAC/R training authority ---www.rses.org
03-10-2012, 10:58 AM #33
It's a smoother, more gradual start because the scrolls take several revolutions to build a pressure that is greater than the discharge line pressure, whereas a recip builds that pressure in a stroke or two of the pistons, which is often one or two revolutions, so the load on the recip motor is much steeper from rest to running at RLA.
2 Tim 3:16-17
AOP Forum Rules:
03-10-2012, 02:31 PM #34
Thanks for all the feedback , help and advice. I really had not heard of those 3-2-1 kits and hope to find a parts place around me that handles them. I also hope there is enough room in these downsized control sections to install them.
03-10-2012, 03:36 PM #35
The internal pressures on the pumping mechanism in a scroll compressor equalize nearly instantly when it turns off because there are no discharge or suction valves to prevent it.
There is a check valve in the discharge outlet of the compressor shell to prevent the system pressures from equalizing through the compressor, but there is no pressure difference across the actual pumping mechanism, so scroll compressor always start fully unloaded.
"5-2-1"
03-10-2012, 04:14 PM #36
03-10-2012, 04:45 PM #37
- Dec 2010
- Palm Beach,Fl.
- 870
03-10-2012, 08:40 PM #38
so I meter the start caps when diagnosing and find some of them bad, I sometimes reuse the existing pot relay and just change the cap. Keep some in my van. Usually the relay is still good. Anyone object to this, I am talking about getting a compressor up and running when it just won't start.......meter goes up and then down on a start cap, I crimp a terminal end on the resistor and reconnect to the terminal when done. What would happen if the resistor was left unattached?
03-10-2012, 08:42 PM #39
I guess I will be throwing away all my super boost. Great thread. This is why I am here every day. Very informative. Thanks for all the info gentleman.
You need to put the phone down and get back to work!
