Page 4 of 4 FirstFirst 1234
Results 40 to 49 of 49
  1. #40
    Southeastern Pa
    Quote Originally Posted by JWB View Post
    so I meter the start caps when diagnosing and find some of them bad, I sometimes reuse the existing pot relay and just change the cap. Keep some in my van. Usually the relay is still good. Anyone object to this, I am talking about getting a compressor up and running when it just won't start.......meter goes up and then down on a start cap, I crimp a terminal end on the resistor and reconnect to the terminal when done. What would happen if the resistor was left unattached?
    Here you go!
    http://hvac-talk.com/vbb/showthread.php?t=467142
    2 Tim 3:16-17
    Member, IAEI
    AOP Forum Rules:
  2. #41
    Aug 2008
    Eagle (Boise), Idaho
    I have freed up seized comressors with 5-2-1
    I started a comparison thread last summer and put down all my findings.
    the kickstart came in 2nd place
  3. #42
    Feb 2012
    Missouri
    I use 5-2-1 or kickstart.
  4. #43
    Nov 2007
    Sherman, TX
    A "true" 5-2-1 is the way to go.
    CSR U-1 and U-2 are stock items in the trucks.
    The Supco SPP6 was also a favorite for years. The caveat was, that you needed to add a delay-on-break timer to use them.
    The advent of digital thermostats with built-in delay solved that issue.
    A Supco has to cool/reset after use. A true 5-2-1 does not.
    Kickstarts are only two wire. We had a case of them, and rewired them all as three wire before using them.
    Technical incompetence is NOT a sales tool....
  5. #44
    Nov 2010
    Missouri
    I alway`s change relay with start cap. Do you tear open relay to look at points?
    usually relay destroys cap by sticking
  6. #45
    Saint Augustine, Florida, United States
    Thank you sir!
  7. #46
    Southeastern Pa
    Thank you sir!
    My pleasure.
    Believe it or not, that popped up on Google. It's everywhere!!!!!
    2 Tim 3:16-17
    Member, IAEI
    AOP Forum Rules:
  8. #47
    Jan 2002
    Palatine Il.
    Glennhvac,
    Johnstone (Gurnee and Niles) and Berkheimer (Arlington Heights and Niles) carry all three sizes of the 5-2-1 kits.
    Note the CSR U3 is specifically sized for 4 and 5 ton SCROLL compressors.
    I also have attached a Bulletin from Copeland listing approved sizes of Start Capacitors for different size Scroll Compressors.
    http://www.five-two-one.com/faq.htm
    From glennhvacman in the NW burbs.
    Hi, my name is Glenn, and I'm a Toolaholic!
  9. #48
    north suburbs of Chicago
    Quote Originally Posted by Glenn Harrison View Post
    Glennhvac,
    Hey thanks neighbor. I could not find them on Johnstone site and just started looking around over the weekend. I did see them at Berk catalog last night. Thanks! We have probably crossed paths someplace
  10. #49
    Jan 2002
    Palatine Il.
    I'm sure we have.
    By the way, Johnstone:
    http://www.johnstonesupply.com/store...2-1&sub=search
