Results 1 to 11 of 11
Thread: Fieldpiece Charging Jacket S365
03-09-2012, 12:44 PM #1
- Oct 2008
- Fullerton
- 699
Jim Bergmann from Trutechtools.com was kind enough to film a test of the Fieldpiece S365 charging jacket. This product allows you to charge TXV systems in weather between 37 F and 70 F. This allows you to extend the billable hours in a day or year and service your contractors during cooler parts of the year when demand calls are low. Check it out and let us know what you think.
03-09-2012, 12:57 PM #2
Where was the low side sensor .2˚-.4˚SH
Was it 37˚F in the shop there?If You Can Dodge A Wrench You Can Dodge A Ball
03-12-2012, 05:11 PM #3
- Oct 2008
- Fullerton
- 699
03-12-2012, 10:23 PM #4
i've been blocking condensers for years.
is an excellent method to ensure charge when the weather man is wrong again
http://www.youtube.com/watch?v=nFl0n...ture=endscreen
06-14-2012, 12:05 AM #5
Has anyone used this yet?
Since my company wants us to do a/c service in cold rainy conditions, including fixed/piston units, can this work on those too?
I had a lesson on charging in cold weather and was shown to raise the indoor to 75° and block the top of the condenser. No SH or SC just 65 & 225 psig and a 17° temp split, R-22.If Guns Kill People, Do Pencils Misspell Words?
http://www.youtube.com/watch?feature...&v=2kX_3y3u5Uo
http://www.youtube.com/watch?v=JVAhr4hZDJE
http://www.youtube.com/watch?v=-TC2xTCb_GU
06-14-2012, 08:32 PM #6
- Jan 2005
- Akron
- 779
JLB- Co Owner TruTech Tools Inc.
06-14-2012, 08:47 PM #7
How accurate is it with a low evap load. Such as return dry bulb 65°?
06-14-2012, 09:04 PM #8
- Jan 2005
- Akron
- 779
08-28-2012, 02:25 PM #9
i like the concept. It should work fine on txv systems, but piston systems could be undercharged and you would/could miss it.
08-28-2012, 02:51 PM #10
- Oct 2008
- Fullerton
- 699
We only recommend using this on TXV systems for the exact reason you state.
08-28-2012, 04:00 PM #11
Russ you may want to look at passing on specific recommendations on taking liquid line temps in cold weather in your manual. You can not simply clamp a ATC1 on a liquid line and expect to get a good reading @37˚F
