Results 1 to 13 of 21
    Jul 2010
    Denver, CO
    How to use sunset/sunrise for a schedule?
    I am looking to use the sunset and sunrise times to control some outside lights. I can't quite figure out how to use them though to do what I want. Is there a specific schedule that I can input the times every day?
    I set up some logic to do a time difference and its turns the lights on when the time difference is positive but I feel there has to be a better way.
    May 2011
    North Carolina
    If you are using a JACE and it has internet access the weather service has a sunrise/sunset time that you could possible use?
    Mount Airy, MD
    The weather service provides Boolean points for this...
    I prefer to back up this with a Boolean schedule and Lumen sensor...
    I give the end user the option of selecting anyone or all.
    Hope this helps.
    Jul 2010
    Denver, CO
    Thanks Chris, I missed that boolean point, it is exactly what I need.
    Mount Airy, MD
    I'd still add some redundancy of some sort...JMO
    Jul 2010
    Denver, CO
    I have it inputing to a boolean schedule so that if it does fault or goes stale the schedule will take over.
    Id like a photosensor but my customer isnt willing to put any more money in the system for a while
    Minnesota
    Quote Originally Posted by Chris_Worthington View Post
    Exactly!
    Sometimes the "Net" doesn't work just all that well.
    Make that ... OFTEN
    Side note: Just got back from a site whose internet connection was just not that often or well.
    Nor was the URL they used to fetch that data.
    A site where I stash some stuff that might be interesting to some folks.
    http://cid-0554c074ec47c396.office.l...e.aspx/.Public
    Mount Airy, MD
    Quote Originally Posted by HuNGRYTeCH View Post
    an "OR" block may work mo better
    Jul 2010
    Denver, CO
    I was considering that, but I set the schedule for the shortest day so I was thinking it will essentially override using the weather service all together...
    Mount Airy, MD
    Better to come on late and go off early is my thinking, Its a fail safe not a replacement for what the weather service provides.
    That's why I prefer the lumen sensor tossed into the mix, can't go wrong and I am covered for stormy weather
    Mount Airy, MD
    I keep calling it a lumen sensor, in reality it is a foot candle sensor and is set at a user selectable setpoint to bring on my lighting.
    Jul 2010
    Denver, CO
    You have a point there.
    I just wish I knew I was doing this at the start of the job and could have put a sensor in my pricing, its much easier that way.
    Mount Airy, MD
    Might want to COV the light output as well in case they notice an issue, makes it easy to see what when wrong and when.
