Results 1 to 10 of 10
    Mar 2012
    Hcshizaki ice maker
    We have a Hoshizaki KML250MAH ice machine. We had to move it because of a renovation that is going on. After the move it will not make ice. The water valve opens and after about a minute or so the compressor comes on and then you here 6 beeps and then after a bit the water vale come back on and the water come out of the over flow. The manual says it is high voltage but that cannot be. Do you think it could be the float?
    Thanks for the help.
    Jan 2010
    6 beeps every 3 secs.= LOW VOLTAGE voltage is 92vac or less.
    Dec 2011
    Asheville, N.C.
    ck. incoming voltage. should have 120-124vac. min. 118.
    Mar 2012
    Checked voltage and it is ok. I removed the float and when the fill valve is on I can push the float up and the water does not stop. Is this a bad float?
    Nov 2009
    Tennessee
    Water pressure to high?
    Mar 2012
    Can you tell me what it should be.
    edit- .. if you have the manual you should be able to determine the basics .... did you ohm the float?
    Sent from my HTC Sensation 4G using Tapatalk
    Nov 2009
    Tennessee
    Jan 2010
    Quote Originally Posted by acbrown View Post
    Recheck your code.
    Nov 2009
    Tennessee
    6 Beeps = Low voltage condition.
