Results 1 to 7 of 7
03-08-2012, 09:43 AM #1
New Guest
- Jan 2012
- 3
Commercial HVAC sizing - Simple Estimation possible?
Hi there,
I am a computer science student engaged in project pertaining to HVAC systems. I have little understanding of these systems but am reading extensively, trying to learn.
I am required to create an application to estimate the size of a commercial HVAC compontent. This means calculating heat/cooling load. I am aware the manual N procedure for commercial calculations, but I am no engineer and am having a little difficultly making sense of it, and cannot afford to buy books on it.
However since I only need an estimation, I am looking for a rule-of-thumb calculation for commercial spaces, could anyone possibly provide me with something like this, or link me to a resource?
I have come accross articles explaining various methods, but they are uncited... http://www.openxtra.co.uk/articles/c...ting-heat-load
How accurate are these methods, and where are their numbers coming from?
I hope this question is not HVAC sacrilege, but any help in this regard would be extremely appreciated
I am in Dublin, Ireland if climate is relevant.
03-08-2012, 04:27 PM #2
Professional Member*
- Jun 2010
- Philadelphia PA
- 2,139
Use my profile and we can "talk" off line.
A little too much for this forumYou have got to learn from other people's mistakes! Because God knows you don't live long enough to make them all yourself !!!!!!!!
03-13-2012, 11:10 PM #3
New Guest
- Jan 2012
- 3
Apologies, I could not for the life of me figure out how to write on your profile, not the usual v-bulletin it seems, or perhaps its my sleep deprevation :P
Thank you for your answer, I have come across such load calculations in the mean time (which I will post shortly), please provide info if you can though :]
However, It seems in my investigation I have neglected AHUs (Air Handling Units). As far as I can tell, these seem to be an all in one HVAC. Would you know of a calculation for the average size required (capacity) for these units? and perhaps an efficiency rating/method? I have been looking, but information is harder to find for these systems.
I have found: http://www.engineeringtoolbox.com/ai...ate-d_882.html
Would this m^3/s or air change rate represent simple capacity requirements for an AHU? Would you have information on these units?
Also, how can one tell when a HVAC component needs replacing?
Cheers, hope you can help :]
04-17-2012, 09:50 PM #4
The only thing i have ever seen to be somewhat reliable, is cubic feet x .075. Then divideby 400. Should put you somewhere in range for a commercial office or retail space.
04-21-2012, 06:47 AM #5
Probably not real close. Most retail has a fair gain from glass, and customers coming in and out of the entrance, along with the large load from the customers being in the store/retail space.
Commercial office space usually has a fair amount of load from equipment.
Both have fresh air requirements which adds to the load. Plus retail has a large load from lighting.
04-21-2012, 11:39 AM #6
04-27-2012, 05:24 PM #7
ntopliffe
Additional infractions may result in loss of posting privileges.
Your post has been deleted
