Results 1 to 7 of 7
    Mar 2012
    Heat Pump in Cleveland, OH
    Hello, The current furnace in my house is over 20 years old. It fires up every winter with no problem. Currently there is a very well known and trusted HVAC company auctioning off a Bryant Evolution Hybrid System. The starting bid is $. I was just looking for some advise on whether or not its a good system and what they normally go for installed.
    Here are the nuts and bolts of the deal:
    Bryant 95% 3 stage up to 120K BTU/H 95% AFUE Variable Speed Furnace.
    Bryant Model 286 16 Seer 2 Stage Heat Pump.
    Bryant Evolution Control
    Bryant 600 Humidifier
    Bryant Perfect Air/Air Cleaner (Electronic)
    Includes Installation And Start up. 10 Year Part & Labor on Bryant Equipment.
    Quote Originally Posted by smithcaj View Post
    The equipment offered would make a good set up for the right home.
    The marketing strategy is also a good set up to obtain perspective purchasers.
    Do you have the other criteria explaining how the process will evolve?
    How are they advertising it, radio,billboard, flyer etc?
    Mar 2012
    My house was built in the 1930's about 1300 sq ft and its forced air heat. The marketing of this is actually pretty neat. It's a cross promotional thing with the major AM radio station in Cleveland. Several business's in town put up things for auction. This is the 3rd auction so its built a good reputation.
    My big question is how do I know the Bryant system would work in my house?
    Mar 2006
    The South
    Smith
    You did not list size of the HP and I assume a matching tin plated Carrier Evap coil is included.
    If you are limited to the furnace size you listed, then certainly it would be grossly oversized. If you could get the right size, then OK.
    Factory warranty will be in effect? Installation included in bid price? Lots f questions that require answers.
    IMO
    Mar 2012
    I guess that it would be easiest if I just provided the link:
    Link not allowed
    Pricing threads are not permitted. The link has also been removed.
    Mar 2012
    Sorry here is the only other info they give:
    Model 355 3 stage 95% up to 120k BTU/H Heat pump 16 SEER model 285 16 Seer and evolution temperature control. This includes installation. 10 years parts and labor on Bryant equipment only. Aprilaire 600 humidifier and 2410 Aprilaire air cleaner.
