Results 14 to 26 of 45
    MEXICO
    Quote Originally Posted by york56 View Post
    What refrigerant is the Chiller using ? Because some are R22 and some are R134a
    your question is not stupid. is correct that questions
    Somewhere in the world.
    York YS
    Quote Originally Posted by servicetrane View Post
    I guess we will have to wait and see what the answer is.
    A mind is like a parachute. It doesn't work if it is not open.
    The best part of going to work is coming back home at the end of the day.
    Hard work spotlights the character of people: some turn up their sleeves, some turn up their noses, and some don't turn up at all.
    Jan 2012
    I believe I wrote in my original post That I had a YS-S2 chiller that we put in 10 gallons of york type C-oil
    I got about 8 to 8 1/2 gallons out that was with a filter change
    Jan 2012
    I should add that before I left for the day,,I jumped the float switch raised the condenser temp/high side pressure and I get plenty of oil back to the separator but it leaves just as quick...now it seems to be more of a surge type of problem
    York YS
    So you still have not answered the question R22 or R134a because S2 is either refrigerant so which one is it ?
    York YS
    Here let try this since obviously I don't know anything , how about posting all your operating data let see if you can do that so we all can take a better look see !
    MEXICO
    sequence E, works or r-22 or R134a
    This is why there is a Pro Chiller Forum because people like this cannot produce the proper info. that is required to troubleshoot the problem that they are experiencing without the proper data needed to help them.
    Jan 2012
    Sorry ...it;s R22
    Jan 2012
    Whatever dude
    MEXICO
    Quote Originally Posted by jaxhd1 View Post
    Whatever dude
    working conditions of the machine:
    temperatures
    pressures
    capacity etc.
    Sorry ...it;s R22
    Thank you that just helps us to help you , next if you could get us the operating data that would also be helpful thanks again.
    Oct 2011
    La.
    Screws do not have surge problems.
