Page 1 of 4 1234 LastLast
Results 1 to 13 of 45
    Jan 2012
    Hmm Ys chiller No oil return
    I have four 300 ton ys s2 york chillers,I got the oil results back and #2 and #3 chiller needed an oil change.So we changed the oil in #2 and it ran for 24 hours and it seemed to be ok so we did the oil change in #3 chiller,then on Saturday the weekend crew said #2 shut down on low seperator oil,when I came in it looked like there was enough oil in the sump so I started it back up and it ran for about 15 min and shut down on low oil.So we checked out the Eductors and they were ok we had already changed the eductor filters so we ruled that out.
    Whats really got me stumped is that I started up chiller 3 today and it is doing the same thing that #2 is. Both chillers were running fine before oil change and now are having the same problem.
    Like I said they are york ys -s2 chillers and the book I have says to use 10 gallons of York type C oil.
    Am I missing something?
    any thoughts?
    May 2011
    North FL.
    What is you entering Condenser temps been running?
    May 2011
    North FL.
    Condenser water temps getting too low can cause you problems.
    May 2011
    North FL.
    Make sure condenser water temps are right, and tower fans operating properly
    MEXICO
    low partial load, condenser water temperature low, low water flow
    Jan 2012
    I have tried setting my tower fans at different speeds and it does the same thing if the CT water is 75 or 95,With a higher head press the oil does return but it leaves almost as fast
    I did notice that my discharge temp is low about 15 DSH and my slide valve never got farther than 40% and the water setpoint is 45 and it never got lower than 47
    May 2011
    North FL.
    Check your flows, odd that it's happening to
    Most of them. Must be WD? Chill wtr and condenser wtr make sure they have the bldg aud . Did you say you are having to run tower fans manually?
    May 2011
    North FL.
    Sorry I can't do more than one thing at a time. Verify proper chill wtr flow. Make sure they have there controls working properly
    Jan 2012
    I don't have to run fans on Man. I just did to get temp up
    What I can't keep asking is why they ran fine before oil change and now shutting down.nothing else was done???
    May 2011
    North FL.
    That you know of, did you verify oil charge plus how much did you remove from each ch
    MEXICO
    oil charge for these machines is 10 gallons. that version is the machine?
    Somewhere in the world.
    York YS
    What refrigerant is the Chiller using ? Because some are R22 and some are R134a
    A mind is like a parachute. It doesn't work if it is not open.
    The best part of going to work is coming back home at the end of the day.
    Hard work spotlights the character of people: some turn up their sleeves, some turn up their noses, and some don't turn up at all.
    York YS
    Reason I ask R22 takes C-oil and R134a takes K-oil just thought I would ask this stupid question.
