Results 1 to 13 of 16
    Oct 2008
    Ventura, CA
    Confused 3 wire pilot burners
    For the last few years, all the 3 wire pilot burners Ive replaced on the older BDP spark ignition furnaces have been failing within a few days to a few months after installing them. Anyone else having the same problem? Am I possibly overlooking something thats causing them to fail prematurely? Ever since the totaline parts distributor left my town, I've had to buy my non totaline BDP pilot burners from Johnstone Supply. Is the different manufacture the problem?
    Also, can the BDP spark ignition system be replaced with HSI?
    Thanks!
    Oct 2011
    Arkansas
    Quote Originally Posted by kirwinjd View Post
    Thanks!
    I've had problems with the 3 wire pilots from Johnstone. I use them as a two wire. I've had two over the last couple of years that were DOA.
    Jun 2011
    Puget Sound area, Wa
    That's why I don't like using aftermarket parts. we found out that a 3/4 HP universal motor(also from Johnstone) doesn't last long in a Carrier furnace.
    Edit: not all aftermarket parts are bad but in my experience they have caused more problems but they are handy if your in a pinch
    north suburbs of Chicago
    I bought one from Johnstone (yeah partly cause they were half the oem cost) and it gave problems. It was short cycling the gas valve off and on. Johnstone said they had a bad batch. The one I had was probably picked up near the end of last winter.
    I have also heard of problems with the off brand boards.
    5,000 ft
    The Robertshaw replacement is problematic. I believe this is the one Johnstone supply is providing.
    Most of the time the spark gap is hard to get correct and if it does lite, the switch doesn't always close for the hot junction.
    You will have to get the OEM part somewhere.
    Oct 2008
    Ventura, CA
    Ok thanks. Of course Johnstone keeps claiming that I'm the only one having a problem with them. FYI: Johnstone was using Robert Shaw but now I see they are selling the pilot burners made by Mars.
    Ohio
    I've had problems with them, but it was my fault when I dropped the orifice and didn't realize it. Oops! Once, the guy before me damaged the bottom of the combustion chamber and air was entering through and blowing the pilot off the sensor. Bent it back as best as possible and sealed it with RTV.
    petaluma,ca
    Thanks!
    Those red,white,blue ones from johnstone don't last very long, i went back to the oem bdp burner to prevent call backs
    Hey they told me I was the only one!
    Kidding. They did say they had a bad run. I tried one cause I was in there for something else and needed one for truck stock. I'll have to go back to the OEM style. That's the one where you feel like you should be wearing a ski hood when you present them with the invoice.
    What is surprising is that it seems three companies manufacture these things. Not the simplest thing to begin manufacturing for a fairly limited demand.
    VA
    If it has a 3 wire or standing pilot, it needs to be replaced...
    It's likely the pick coil is starting to fail. If you think the pilot is expensive, you should price the oem gas valve.
    "The only true wisdom is in knowing you know nothing" Socrates
    Visit us at Dr. Degree°s HVAC
    or like us on Facebook
    Massachusetts
    I used to carry those pilot assemblies but the last one went out the door about 2-years ago and it had been on my truck for 5-years. IMO those old furnaces are in need of replacement just due to age! Not energy efficient by today's standards and in our area, the numbers are so thin that it's not worth stocking repair parts. That can leave the customer with no heat in cold weather (just like a lot of other things, admittedly) when it could have been avoided.
    Oct 2008
    Ventura, CA
    Thanks for all the input. But can anyone answer my second question: can I convert the BDP spark ignition furnace over to HSI? Is there a kit out there that the existing wire harness can plug into the new control board?
    Is it just a spark pilot without an inducer?
