Results 1 to 8 of 8
    Aug 2005
    San Diego,CA
    410A discharge line temp??
    Does anybody know what the actual discharge line temp is on a 410a system at 65f ambient?
    Sink or Swim!
    A Man has to know his limitations..
    To be old and wise, one must be young and dumb..
    Mar 2011
    So many variables...
    Aug 2005
    San Diego,CA
    When everything is perfect...
    My boss wants to install a plate heat exchanger off the discharge..
    Sink or Swim!
    Mar 2011
    What type of system are we talking about here? Air cooled? Water cooled? High efficiency residential? What does the cooling load look like? The discharge superheat (and actual line temp) can vary quite a bit depending on the system load and effectiveness of the heat exchangers. What are you looking to do, heat reclaim? You may be able to calculate a number at design conditions but there again it's usually a small fraction of the operating hours. If you are doing heat reclaim the goal is to capture as much heat as you can, so one would select a heat exchanger with somewhat larger capacity than the compressor.
    Aug 2005
    San Diego,CA
    Ok, how about a ball park under low load conditions. Let's say 20 ton rtu.
    Sink or Swim!
    East of big city prices.
    Probably going to run about the same as R-22. 120-180 like as been said too many variables.
    Mar 2011
    Low load air cooled rtu at 65* ambient with some OA and 48* return gas? One would be lucky to hit 135*
    Aug 2009
    Prattville, Alabama
    Quote Originally Posted by thegoodlistener View Post
    I agree. Years ago, I was told by one of my mentors (who is long retired) that given all other things being constant (operating conditions, ambient conditions, efficiency, application, etc...), that when comparing different refrigerent systems (r11, r22, r12, etc...) the temperatures don't change, just the pressures those refrigerents operate at. I have found that to be very helpful.
