Results 1 to 10 of 10
Thread: VFD on an Air Raid Siren?
03-06-2012, 07:18 PM #1
I have a buddy who is a volunteer firefighter, his department is looking to get rid of a old air raid siren that they sound anytime there is a fire call, it's kind of a tradition in volunteer FD's. They claim it costs too much to sound the thing. I suppose they are looking to "go green" with a electronic speaker siren.
I suggested putting a VFD on it to help with the cost but the more I think about it it may end up distorting the sound only running at say 75% of speed and once you go to 100% you aren't really saving much.
What says the hive?
Video of a like siren.
UA LU189
10mm, because it's better than .45acp
03-06-2012, 07:24 PM #2
i dont know if it would work but i would love to try it!
IV IV IX
use your head for something other than a hat rack.......Gerry
03-06-2012, 08:39 PM #3
Sounds like a York air cooled chiller. Screw compressors on a drive that run up to 200 hertz
03-07-2012, 08:45 AM #4
- Feb 2012
- Upstate SC
- 84
I am aware of a situation like this, however it was the fact that it was a three phase motor and it was the minimum power company charge that was costing them so much and not the actual usage.
03-07-2012, 09:26 AM #5
03-07-2012, 10:07 AM #6
Could you use single phase power and install a VSD and use it to create your 3 phase power source??? To avoid power charges?
03-07-2012, 02:44 PM #7
- Mar 2010
- Kent, WA.
- 155
Experience
Is what you get when you didn't get what you wanted.
A positive attidude will not solve all your problems, but it will annoy enough people to make it worthwhile.
03-07-2012, 07:45 PM #8
- Mar 2003
- 7,253
check with your utility to see if you can get a rebate for installing the vfd, lol.
03-07-2012, 10:32 PM #9
If it draws 100 amps at 240V for 3 minutes, that's 1.2KWH for each fire. at $.13 a KWH, that's about 16 cents for each fire.
I think the fire sirens are a nuisance now that we have other ways to communicate but if the FD doesn't mind annoying the neighbors in the name of tradition, run the siren they have.Ryan
Maintenance Guy
naysayer, skeptic, conspiracy theorist
03-10-2012, 12:02 PM #10
- Jun 2010
- Southwest NM
- 22
Feeding a VFD with single phase power
Just be sure there's no hard-wired phase failure shutdown in the VFD firmware. Most anything 3HP or less comes equipped for single phase input (rectifier diodes rated for at least 1.73x input current, no phase failure shutdown.) Gets a little tougher at 5HP - the Hitachi's we used to use were discontinued a couple years back.
